The gap between Standard and upgrade Suspension
Started by jvanzyl, December 14, 2015, 10:33
Just for clarity the £36 was for a four wheel alignment.
Looks to be good value.
Jason that's cheaper than tweeks do it at ding day club discount.
Are you SURE you got a full wheel alignment?
It's usually 100+ although I have coilovers and therefore more adjustments can be made.
£66 proper cheap sounds like they're doing the works though.
weeJohn
I can get a 4 wheel alignment done here in N. Ireland for £40, and our government still doesn't allow gay marriage or abortion its that backwards.
weeJohn
Rear camber is pretty matched but you would have thought they might have loosened the bolts holding the hub to the shock and tried to even up the front a bit more.
