Dashboard lamps
Started by Nunfa1, February 6, 2016, 13:27
Nunfa1
Hi all, does anyone know what size lamps go behind the heater dials? I've removed the old one but there doesn't seem to be any markings on there and they're not listed in the handbook either.
Ta
I wonder if the next thread down from this provides an answer for you?
Barney Bear
be warned their not cheap and the bulb doesn't come out of the green plastic holder also MrT said their listing showed only one needed but mine had two
54 Sable, Air con, hardtop
Nunfa1
Quote from: "loadswine"I wonder if the next thread down from this provides an answer for you?
Doh! I did a search a few days ago and nothing came up so just posted without looking. that'll teach me   s:D :D s:D
How much?! I'm going to do some research and try to find an alternative, plenty of different options about, just got try and find the right size.
will update if I find something suitable.
Nunfa1
So, the answer is T4.7. the lamp base is 12mm diameter and 9mm high. I ordered some LED ones and they do fit and they do work, but I'm not sure LEDs are really suitable there. The light spread is not really wide enough so it looks a bit dim once the dials are fitted.
