Mini supercharger on 1zz
Started by Carolyn, February 26, 2016, 19:14
Essex2Visuvesi
#300
Quote from: "Carolyn"
Quote from: "lamcote"XP!!!!
Really.  All my mechanic friends run diagnostics and flashing on XP
Many of the connectivity issues are down to the Serial-USB convertors people try to use.  Most of them don't work too well causing communication issues & "lag" in the data stream
Shout if you need an XP laptop with a true 9 pin serial port. I have an old dell sitting here specifically for this reason
Its running an SSD too so its quite lively   s:twisted: :twisted: s:twisted:
Essex2Visuvesi
#301
Oh and its payday today so bought myself a supercharger  s:D :D s:D
Going to design and make up some outlet flanges for the outlet and pass them onto Carolyn with the 120mm pulley, should make fabrication easier
lamcote
#302
You absolute star
Carolyn: I hope your friends don't go on the internet with their XP machines...
Essex2Visuvesi
#303
Quote from: "lamcote"You absolute star
No Problem.
I might be able to offer up a second one if I can find another PSU pack
One NEVER goes on the internet with one's garage computer.
lamcote
#305
Oh, I see.
Essex2Visuvesi
#306
I know. That's why I'm borrowing an XP laptop today  s:) :) s:)   The software was built for Win98. Win 2000 at a push,which is why it works on XP
Quote from: "Essex2Visuvesi"Oh and its payday today so bought myself a supercharger  s:D :D s:D
That is very kind of you.  I'm struggling to remove the pulley without buying a special puller, as I'd rather not use heat on it.  Probably will end up getting the special puller! (Or persuading David to make one...
With you on board, and therefore a parallel project in progress, I think it might be good for me to take a more of a back seat for now.  I've been finding this a bit stressful, to be honest.  We will work on the subframe and follow on on the rest of it.  I'm not quitting, but I am slowing it down for my part.
Essex2Visuvesi
#309
The challenge is to pull it off without bending it.
The correct tool spreads the load around the pulley... shouldn't be too hard to "Macgyver" something
You're right  we'll have a go over the weekend.
lamcote
#311
There's absolutely no rush Carolyn, don't get stressed whatever you do. I know I keep firing stuff around on here but I'm in no hurry whatsoever. Looking forward to seeing the results of the subframe solution as and when it arrives.
Thanks again for starting this all off, we'll get there in time.
Other laptop ended up being Win7 as well. And it's a piece of sh1t and I want to toss it out the window.
I need to just buy a cable from GiffTech with software, which works on Win7.
Sick of this. I'm not trying anymore using DIY stuff
I have a little netbook on XP -but it's lent out at the moment...
On another note, I need to photograph the mounting brackets so you don't have to re-invent them.  There's also provision for an extra idler wheel to enable the belt to clear the bottom of the tensioner spring unit.  We're making ours using a skateboard wheel - don't laugh, they're tough. Got a couple of spares.  This will especially be needed with a 120 mm pulley.
These guys have tons of cheap netbooks on XP.
 m http://www.ebay.co.uk/itm/Acer-Aspire-O ... Swc1FXcU8I m
I'm going to have to borrow. I'm going to check again as I had someone lined up to lend me a laptop
Essex2Visuvesi
#316
Quote from: "shnazzle"I'm going to have to borrow. I'm going to check again as I had someone lined up to lend me a laptop
If not give a shout and you're welcome to have a loan of mine
Cool thanks. Will do
Once upon a time......
I had a netbook on Win7, I bought Gifftech cable and software......
And it worked without trouble.
Must have taken all of 15 minutes to order, install and get working.
Then i tried it on a full size laptop running Windows7 ............ it worked.
I haven't tried it on Win10 64bit yet.
The moral of this fairy tale?
Why bother f---ing about when there's something available that's reasonably priced?
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
Quote from: "Wabbitkilla"Once upon a time......
Exactly.
Good to know that it works on a "normal" laptop as well.
DEfinitely ordering this then. It'll have to wait a month though
lamcote
#320
Shnazzle, is it possible to connect the Emanage ECU to the car and set it up with a neutral map which applies no changes at all to the fuel and ignition timing? Could we then log the settings the car is running on in that state? If so, this would allow us to determine what the standard ECU's fuel/ignition maps are.
Yup you can just zero all the cells, in which case it just runs without any adjustments. Then monitor. Although, as I said, I don't know exactly what kind of monitoring it offers
lamcote
#322
That could be helpful. Does the Blue have a lot less logging capability than the Ultimate?
Quote from: "lamcote"That could be helpful. Does the Blue have a lot less logging capability than the Ultimate?
Not sure. I suspect you can log everything we need to log. The blue can adjust timing and pulses so surely it has to see what the current values are to do so.
So I assume we can log anything of any relevance. Air flow, timing, fueling... Pressure if a gauge is connected...
lamcote
#324
Just as an update, I have looked up the option of variable/higher fuel pressure as mentioned by Chris earlier. As far as I can see, with our returnless fuel system, implementing higher/variable fuel pressure would seem to cost in the region of £300. This is a significant chunk of the cost of just buying a piggyback ECU, be more complex to fit and have less flexibility. So, unless anyone can point us to a simple and cheap version, I don't see this as a viable option.
As another thought regarding my ignition timing worry. If we accept that the assumption about needing 1-2deg of ignition retard/psi of boost is correct. At our projected max boost of c.5psi we will need up to c.10deg of retard. If we use super unleaded fuel for our test runs, that might buy us (at least?) that much timing advance, so it's just possible that would solve the ignition timing issue....??
