DAB antenna.
Started by Thetroublemaker, June 4, 2016, 13:43
Thetroublemaker
Has anyone put a DAB unit in their car, and if so did they use a replacement to the OE antenna or a film type one?
cptspaulding
I used the autoleads film type on the windscreen. Works a treat  s:) :) s:)
Sent from my LG-H815 using Tapatalk
Lank
Quote from: "cptspaulding"I used the autoleads film type on the windscreen. Works a treat  s:) :) s:)
I have the same and it works ok. there are two small black spots on my way to work that I do not get signal but its literally for a second or two. Signal is fine in my other car that has DAB as standard
also check the aerial spec and stereo, some stereos have a setting where it needs to send voltage to the antenna which improves signal
lemans
I used the Autoleads film type too.  I have one "dead spot" locally at the bottom of a valley which is also a mobile phone dead spot. Otherwise it works very well. I was quite surprised such a small antenna works so well.
Daryl
Facelift Black MR2 with red leather interior. Hardtop, rear brace, SP body brace, Mongo\'s & SP Turbo - 238bp, 220lbft.
