1zz help/advice
Started by paul.mcgrath, August 31, 2016, 09:03
paul.mcgrath
#50
From the pics I have been sent my  MRS engine has a single exit pipe unit
Coming out at 90 degrees just above where oil filter I assume is screwed in ....
New 04 engine has two  pipes that exit out just above oil filter that turn upwards with rubber hoses connected but where
do I connect them , wish I could post the pics but can't at the moment , the pics posted don't show what I'm looking at
Thanks for all your help
2000 MRS Blue , 2004 facelift engine , Whifbitz Turbo conversion 176bhp 190lbft, hardtop ,Meister coilovers, R8 18&19" wheels, Matt brace
facelift headlights , Monocraft bodykit
The roadster come with an oil warmer as standard that is what your looking at. Now the import did not have the warmer as standard so that the difference. Now if they are using your water pipes from the old engine for the new one you will just leave the warmer alone. One pipe in and one out it won't hurt it.
paul.mcgrath
#52
Thanks been a great help as always
Hopefully the rest will go back together with no more problems
I'm looking at a baffled sump and oil coolers , moroso for the sump but what oil coolers fit ?
lots of opinions on oil coolers but for me regardless of manufacture it should be thermostatic to allow  oils stay at a better constant which is important on a turbo car.
paul.mcgrath
#54
Hi all , car all back together and running well now , looking around and I came across this
 m http://www.rsaperformance.com/obxaloilpanw.html m
any feedback out there as to if its any good ? lot cheaper than moroso is there a reason
also where's the post on how to put pics up on here .........?
thanks
tommyzoom99
#55
Quote from: "paul.mcgrath"Hi all , car all back together and running well now , looking around and I came across this
thanks
dont get it mate, i brought 1 was a absolute nightmare, ended up getting a elise parts sump
 l viewtopic.php?f=7&t=56489&p=653654&hilit=obx+sump#p653654 l
cheers tommy
My track project
viewtopic.php?t=51237
paul.mcgrath
#56
thanks Tommy , wont bother , is it money well spent for the elise parts sump ?
Quote from: "tommyzoom99"
thanks
 m http://www.mr2roc.org/phpBB3/viewtopic. ... mp#p653654 m
cheers tommy
What made it a nightmare?  Fit?
tommyzoom99
#58
Quote from: "paul.mcgrath"thanks Tommy , wont bother , is it money well spent for the elise parts sump ?
yeah to be fair the elise parts sump was in a different league, they are the go to sump if you have a 1zz or 2zz and are doing track days. and have all the bits ready on them if your going turbo
cheers tommy
My track project
tommyzoom99
#59
Quote from: "Carolyn"
thanks
cheers tommy
literally about 3 holes lined up had to drill out every hole to a oblong shape, the welds where not the best, then after all that got the thing on bolted it up and a weld had cracked at a corner and was weeping oil, so threw in the towel and got a elise parts.
cheers tommy
My track project
paul.mcgrath
#60
on the other hand maybe a calculated risk ........?
paul.mcgrath
#61
Hi all , any comments or feedback about the
Wilwood brake kit would be appreciated
or any replacement suggestions ??
