headlight bulb q
Started by robLFC, November 24, 2016, 16:37
robLFC
hi has a 2003 mr2. it has seperate dipped and full beam bulbs on her car light unit .
i thought the driving dipped bulb was an h7, but it seems the wrong fitting now i have them so i need to buy correct ones
what is the exact bulb fitting ie h3 hb3 h4 hb4 etc ? so confusing and i dont want to shell out for more wrong ones !
thanks
ps - i have changed the sidelights easy enough to newer led white bulbs , so presume its definitely a facelift as i understand to change pre facelift i wouldnt be able to do that lol. its also a 6 speed box and has front fogs so pretty sure its facelift !
brettfield999
Hi rob, if it is a FLwith original headlights it'sa H7, bear in mind the facelift has a black adaptor thing from Toyota.  When you removed the old bulb you pull this off and put the new bulb on it.  I'm not sure what the "thing" is called but it makes the bulb longer.
From the front you shouldn't be able to actually see the bulb as there is a dome over it; is that what you have?
[strike]2000 Blue PFL MR2 Roadster with 187K, engine blown[/strike]<br />[strike]2000 Blue MRS, 80K[/strike]<br />[strike]2001 Blue PFL MR2 Roadster 131K, 2ZZ,[/strike]<br />[strike]2003 Silver FL MR2 Roadster with 81K now daily driver, 2ZZ by Headcase[/strike]
robLFC
its like a projectory 'cyclops' opaque domed thing that you cannot see actual bulb mate yes .
ive reassembled now, but when i pulled bulb out it was totally wrong looking black bit so i put it back together !
side wedges where so simple  s;-) ;-) s;-)
thanks
robLFC
actually thinking, maybe its got the wrong bulbs currently fitted in there ?
the new one is definitely an H7 fitting , looks like this :
 w www.soullure.com/popup_image.php?pID=50 ... d150ea1f8e w
once i unclipped the wire frame and removed the existing bulb i saw the black plastic part was different i put it back in , perhaps i should have a go at mounting tomorrow
