195/50/15 AD08R & 215/45/16
Started by swandez, January 3, 2017, 21:13
swandez
Having a tyre size dilemma, decided I'm going for the AD08R however I'm dubious of upping the rears on my facelift rear wheels to 225/45/16 due to the larger sidewall & increase in ride height/reduced acceleration.
My question is if I stick with the stock 215/45/16 is there enough of a stagger to up the fronts from the stock 185's to 195's?
I've been running 195f and 225r AD08Rs for years. Wouldn't have it any different.
I wouldnt say it's slower. It might be on a track against the exact same car, driver weight, etc with stock size tyres. But in real life? Nah
mikek
+1 195f 225r. I run these sizes on mine also stock wheels. Same sizes but toyo's on kates car. No issues and more grip.
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
swandez
Ok cool that's good to know I might have to just take the plunge a go with the 225's....
Assume this setup is a decent improvement over stock?
Swandez
If not upping the back why up the front.
I'm running AD08Rs in stock sizes. Never once felt I needed more. Not in my B road world.
Track - maybe.
AD08Rs in stock sizes are a big improvement over OEM tyres.
What condition is your suspension in? old? new? stock? coilys?
When these components are fresh and fresh rubber.
Get a high quality Geo done to pull it all together.
I have fresh stock suspension and 08 tyres. But it was not until the geo was done did it all work in harmony.
I went to wheels in motion to get mine done.
Car has never felt so planted.
Well worth the trip.
I went for 195 and 225s when I got my new wheels but recently have had to put the standard wheels/bridgestones back until I can roll the arches (due to the new ET) and the first time back on standard I did think it was it accelerating quicker.
I am happy with my choice for my use though and they are great tyres which I cant wait to get back on the car.
swandez
Quote from: "Ardent"AD08Rs in stock sizes are a big improvement over OEM tyres.
Not long had Tein springs, whiteline camber bolts & geo done at Rouge, front camber -1.5 degree +1mm toe, rear -2 degree -2mm toe....
Fresh shocks same time as teins?
Teins same as you.
Fresh stock shocks
Mr T bolt (90105-14147) for camber adjustment £3.50
Dudi
What size AD08R would be advised for track use on facelift 15F 16R wheels?
if you are running stock power I would say stock sizes.
Other opinions will no doubt suggest otherwise
Huambo81a
What size would you recommend so i can put an order in?
I have a 2zz, so woud like to go 225 rear, and 195 front. What are the specs i need?
2ZZ - Apexi PFC - Proflow Exhaust - Yellowspeed Coilovers
I went for 225/45/16, 195/50/15 yokohama ad08rs but I am not sure if there were any other options with a lower profile?
Dudi
I've got a 2ZZ as well, would like a neutral to slight oversteer balance and from past experience increasing the width of the tyres tend to favour that balance. Factory setup seems to favour a more safe/understeer setup.
Does a square setup work quite well for track MR2's? If so what sizes?
Dudi.
Sounds like you know what you want handling wise.
Once you have you tyres. Visit wheels in motion. They can dial in whatever setting you like.
Have you  considered a career in sales Jason?  s:) :) s:)
I'd make a better heart surgeon than salesman. Rubbish at selling stuff. End just giving stuff away.
Just one for giving credit where it's due.
When you visit them, they ask you what purpose is the car to be used for, stock, fast road, track or whatever.
I wish they were a bit closer
Dudi
I take my other cars to Litchfield motors for alignment and setup but will have a look into Wheels in Motion.
I think running square setup would be ideal for tyre wear and possibly running with spacers at the front for increased track but able to switch them onto rears when necessary.
Shnazzle
So do I. Relatively speaking.
