Enlarged Throttle Body
Started by Essex2Visuvesi, February 24, 2017, 12:23
Essex2Visuvesi
Quote from: "Wabbitkilla"When I had the Apexi intake and bored TB I used to nearly max out the MAF on WOT
Is there any real advantage to running an enlarged throttle body?
I was thinking of adding one when I go turbo
If anyone is after an enlarged throttle body, I will have one available shortly.
Funny enough... I was just talking to Nic about where to get one Nigel
Essex2Visuvesi
Quote from: "shnazzle"Funny enough... I was just talking to Nic about where to get one Nigel
Here:-
 m http://maxbore.com/index.html m
has a very good reputation on other forums
Yeah I'd rather not pay the import/shipping  s:) :) s:)
Drop me a line Nigel when it's off. I'm assume it's Nic's old Maxbore
Essex2Visuvesi
Quote from: "shnazzle"Yeah I'd rather not pay the import/shipping  s:) :) s:)
Won't be any duty if the paperwork is done correctly.... Its a warranty reapir  s;) ;) s;)
lamcote
Do I remember an issue about a peculiar lack of engine braking after fitting a bored throttle body or am I making this up?
Quote from: "lamcote"Do I remember an issue about a peculiar lack of engine braking after fitting a bored throttle body or am I making this up?
I don't remember anything like that but mine had a lightened flywheel too which affects engine breaking.
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
lamcote
I have been searching the forums and have found that in 2007 a certain Wabbitkilla said this about his bored out throttle body:
"With the TB alone response was quite interesting. You can hear the engine breathing deeper and throttle response was definitely quicker, especially when you were already carrying momentum. The wierdest thing was the reduced affect of engine braking. Adding the lightened flywheel and clutch brought some of the engine braking back which is kind of wierd but at the same time pleasing."
I haven't read all the thread, maybe this was eventually attributed to something else?
Mikeymead
There is a company called Streetwerks that are offering bored out throttle body's.
Essex2Visuvesi
Any contact details for them other than faecesbook?
moved this to its own thread to stop dirtying the intake test thread  s:) :) s:)  Scoundrels
Hmm..  'enlarged throttle bodies' eh?  Get them from some site on the net??  Perhaps this should only be discussed in private.  Be warned - the effects are temporary.
lamcote
Some of us need all the help we can get, temporary or not......
Mikeymead
 l download/file.php?mode=view&id=495 l
Example of Streetwerks urm work
Nic, just noticed your thread on Spyderchat.
You said you had to tweak the tps signal using the EMU, until you got the apexi pic. Is that still the case?
Can't do signal translation with the EMB so I'd be pretty stuffed for the enlarged throttle body
Jacobsprky
i would be interested in this myself. thinking of doing it myself, port and polish and knife edge. will get a spare case i mess it up. i think as long as you dont mess about with the seat of the butterfly flap shouldn't mess up tps reading? didn't a chap called custard do boring? Jacob
01 Silver PFL
hachiroku
Quote from: "loadswine"If anyone is after an enlarged throttle body, I will have one available shortly.
I will definitely take this off your hands if no one else wants it, myself and Tommyzoom have recently been in contact with Maxbore regarding sending one out to him for modification, so this would be perfect for us.
Just name your price  s:) :) s:)
Too late  s:) :) s:)  tis mine hehe.
Did you check with Streetwerks? Their price si 165 I think. Might be close to Maxbore incl shipping and all that
hachiroku
No worries Patrick, wasn't sure if you wanted for definite as you mentioned possible compatibility issues with your EMB.
Haven't checked with SW as yet... will look into them.
woodypk
Apologies for the revival but I noticed that the thread is less than a month old so I thought I could get away with it  s:P :P s:P
Does anyone know the exact internal diameter of the enlarged throttle body vs standard? I have a very talented machinist at work who would give this a go if I asked him. I may end up taking the TB off my old '2 just in case I screw it up!
Black W reg standard - Gone
Sable 06 Reg turbo - staying forever
If I were to add up how much I'd spent on my car, I still wouldn't be able to afford a new Vauxhall Corsa - And I know which one I'd rather have...
hachiroku
Quote from: "woodypk"Does anyone know the exact internal diameter of the enlarged throttle body vs standard?
I've just bought a 1zz TB from Streetwerks, it's gone from 55mm to a safe maximum of 59mm. That also includes a new larger butterfly valve to suit. The Maxbore retains the stock butterfly as far as I'm aware, not sure what the diameter is on those.
Maxbore has a larger butterfly as well. It has to.
Probably also about 59mm. Can't really go much wider.
Be careful with the gasket. It's a bit of a pig
woodypk
OK thanks guys. Do you have an idea of what the material of the butterfly is? I know it seems a bit of a pig modifying this when I could just buy another, but at work I'm sure were capable of making things like this. Plus, it saves more pennies which I can use at the fuel slot machines.
It's not that easy but if you can get it done, all the better.
Need to bore out the body straight and even. Then get a brass butterfly cut. Then widen the slot in the spindle.
