Scotts Yellow Supercharged V6 Roadster
Started by 1979scotte, March 22, 2017, 07:27
Quote from: 1979scotte on March 22, 2018, 17:48
Quote from: wotugonado on March 22, 2018, 17:08
:) Will the expensive fettling never end
Yes.
Eventually we all die.
You could add a codicil to your will???? 8)
Angpozzuto
Glad to see you've got it back on the road, you're making a little bit more power than mine (242hp and 232ft/lbs) but I'm planning on getting the exhaust y pipe redone and water meth injection so I should catch up [emoji12]. Be sure to get yourself over to a Kent run soon I'm looking forward to having a good look at this beast
Quote from: Angpozzuto on March 22, 2018, 20:37
Best of luck mate.
Do you really want more grunt?
240 in a MK1 will be eating MK2 turbos no problem.
Angpozzuto
Quote from: 1979scotte on March 22, 2018, 21:10
Best of luck mate.
I know what you mean especially with a car that has no driver aids and stock sized brakes, but I just want to make it as good as it can be without adding more boost
chasmundo
Quote from: 1979scotte on March 21, 2018, 20:42
Home.
It's bloody quick.
Too quick for the road if I am honest.
Makes some interesting noises.
And the rear dampers need firming up because she squats down like an American muscle car under WOT.
Can you turn the boost down for everyday use / wet road conditions ?
Quote from: chasmundo on March 23, 2018, 12:34
Home.
It's bloody quick.
On Angelo's it's a definite no.
TRD blower only changes pressure via a pulley.
On mine ATM it's practically a no. I could manually turn the boost down but it's a pain.
If I had electronic boost control it would be very simple to lower the boost.
I am looking into having my DET3 PIGGYBACK control it. Should be possible with a solenoid.
chasmundo
Quote from: 1979scotte on March 23, 2018, 15:34
Home.
It's bloody quick.
Well I have bought a boost controller for the turbo conversion and Patrick is going to see if he can make it work with the stock ECU.
I am just going for a mild upgrade in torque to cure the flatish mid range 3000-6000rpms. Hopefully reaching 180-190bhp ...Nothing like yours. That much power would scare me silly, but each  to their own and yours is as unique as they come...a yellow rocket ship.
If he can't get the ecu to work, I'll also have to go down the det3 and piggyback route. I need it to be a fun and reliable as it will be my daily car ...rain, shine or snow!!
My wallet is feeling the pain in the pursuit of madness [emoji22]
chasmundo
angpozzuto - I think I might poo myself in a mk1 with that much power and stock brakes. I already have to stand on my brakes hard in my standard mk1 when I am hammering it.
Maybe the saying "with great power comes great brakes" is more applicable than ever in a mk1. At least the mk3 brakes feel as good as a modern car.
Enjoy and be safe
Quote from: chasmundo on March 23, 2018, 17:44
I understand your pain but I've got to say that for the money it's silly not going for a Det3.
I was going to try and use the stock 1mz ECU and go low boost but for 150 quid why not. It's safer and makes more power.
Got to say that if you want it to be your daily driver and reliable doing it on a really tight budget might not be advisable.
chasmundo
Quote from: 1979scotte on March 23, 2018, 18:14
I am just dreading Patricks call telling me just that !!
I am slowly resigning myself to det3 + 2zz injectors....its nearly pay day
chasmundo
Can you send me a link to the injectors you bought for £150 in case I get that call from Patrick.
[emoji106]
MR TWO
Home.
It's bloody quick.
I've thought that a few times about vechicles I owned, usually just after purchasing, or adding some extra ponies.  Its a feeling that always went away!
Quote from: MR TWO on March 23, 2018, 21:54
Home.
It's bloody quick.
Pretty sure the feeling will go away however the Speedo and the smell of the breaks pads won't.
Not had it up to 6 psi since the day I bought it home. 5.05 psi just now.
Love the noise. Not the V6 the Rotrex. It just sounds so futuristic.
Angpozzuto
Quote from: chasmundo on March 23, 2018, 17:49
Enjoy and be safe
I don't think bigger brakes will make a huge difference, if I can lock up my current tyres braking force isn't the issue grip is the problem
This is what happens when I had to stand on my brakes on an airfield day, I went from 100mph down to 30mph and scrubbed 4mm of rubber off them
As they are not on the car, is it safe to say they are basicallly f :( :( ked
Angpozzuto
Quote from: Ardent on March 23, 2018, 22:48
Yeah they had to go, it was like driving on 50 pence coins the vibration was ridiculous [emoji23]
Quote from: Angpozzuto on March 23, 2018, 22:33
Enjoy and be safe
What are they? AD08R? Really like them on the road never taken mine on track.
I am thinking nankang nsr2 or federal 595rsr if I can find the right sizes.
If not Toyo R888.
Also what pads are you using?
Angpozzuto
Quote from: 1979scotte on March 23, 2018, 23:02
Enjoy and be safe
If not Toyo R888.
Yeah they're ad08r, I've never taken them on a proper track day I've just done a few airfield days at north Weald on them and they are awesome. What tyres and sizes are you running on yours?
Quote from: Angpozzuto on March 23, 2018, 23:10
Enjoy and be safe
If not Toyo R888.
I am on PFL stock MK3 sizes 15" 185 front 205 rear AD08R.
I am running 195 and 225 on mine, cant help but think you should be too!
If you went to FL 16" rear wheel you may get less tyre "squat" under acceleration?
jonbill
Quote from: Angpozzuto on March 23, 2018, 22:59
Didn't the ABS work?
ayresyboy
Quote from: jonbill on March 24, 2018, 08:18
No ABS on Mk1's
1997 MR2 V6
2003 Caldina GT4N
jonbill
Quote from: ayresyboy on March 24, 2018, 08:20
No ABS on Mk1's
Ah, missed that bit [emoji847]
Quote from: jonbill on March 24, 2018, 08:33
No ABS on Mk1's
Easily done.
For future reference Angelo's car is a MK1 with a 1mz V6 swap and TRD SUPERCHARGER.
Quote from: Topdownman on March 24, 2018, 08:16
It wasn't the tyres it was the dampers they're in a very soft setting.
I have FL wheels in the loft but I will wear out these tyres first.
Even then not positive I will go to FL wheels so much more playful on the smaller ones.
