engine in facelift better MYTH ?
Started by ilovejapcrap, June 2, 2017, 23:52
ilovejapcrap
So a quick glance at a mr2 buying guide says mr2 FL are better and don't have stuck oil ring issue.
Yet people still report the issue ?
Anyone seen the later piston set up in say a 04 plate I'd love to see if it's different. I have seen pictures of the new piston with 4 holes but when did they actually alter to them ?
jonbill
I think I read it was only in 06 they got that piston revision
disssoof
I'll be dismantling a late 04 in a couple of weeks.  I'll take some pics. It's an oil burner btw.
ilovejapcrap
Quote from: "Carolyn"I'll be dismantling a late 04 in a couple of weeks.  I'll take some pics. It's an oil burner btw.
Ok interesting stuff
ilovejapcrap
I wondered if they did small updates as it went on but it would seem not
2 of the left
I have both versions pfl/fl, both have precats removed !! - Have no probs on that front!! pfl 02 plate / fl 04 plate
SI VIS PACEM PARA BELLUM!!
The Other Stu
Quote from: "ilovejapcrap"I wondered if they did small updates as it went on but it would seem not
If only there was a thread in the reference section   s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
http://mr2roc.org/phpBB3/viewtopic.php?f=46&t=4807&sid=bff156d439ab89bea3a088f690903ec7
Interestingly, it doesn't mention the revised oil rings in 2006. It was written in 2004, and revised in late 2006.
I don't think it became "common knowledge" about the oil control rings until later.
But this is the salient point
Quote2002 - Addition of improved Oil Control Rings fitted to the Pistons.
I believe this actually came in just before the FL, hence why it's generally accepted that the FL engine is slightly more reliable on that front.
However, you'll find a lot of people here will say - doesn't matter if it's PFL, FL or even the post 2006 engine. If it's not been properly serviced and looked after, it'll likely be an oil burner at some point.
lamcote
According to Matt Performance the 2002 oil control rings helped but didn't completely solve the problem, so the revised pistons with more holes were then introduced in 2006ish.
I have taken the pistons out of the 04 engine.  The oil control rings are gummy but NOT stuck.  Bores very glazed and bad valve seals in the head.  Piston ring gap over tolerance.  Better with new ring.
This engine was using oil and the oil was going black, so I put it down more to valve seals than to gummed up rings.
jonbill
Quote from: "Carolyn"I have taken the pistons out of the 04 engine.  The oil control rings are gummy but NOT stuck.  Bores very glazed and bad valve seals in the head.  Piston ring gap over tolerance.  Better with new ring.
That's a bit of a surprise to me. They're not all the same then [emoji849]What do you put the ring clearance down to? Ring wear or bore wear?
Ring wear and glazing as far as the bores are concerned.  Exhaust valve seals buggered.
Edit:  This engine had been Forte flushed.  It is far and away the cleanest 1ZZ I've opened up.
Quote from: "Carolyn"Ring wear and glazing as far as the bores are concerned.  Exhaust valve seals buggered.
Also.  I've taken the oil control rings off the old pistons.  Judging by the amount of build-up of muck behind them, they weren't doing their job.
Davred
Had my engine rebuilt by Matt performance in May 2014 with new pistons and he commented that they were a modified unit yet again?
Ongoing story then!
W. Red. Black leather. Facelift wheels.Toyo T1R. Pre-cats removed. Matts TTE style chassis brace. 2003 facelift front brace, FK lowering springs, Dev keyhole covers, tte rear grille. Tanabe G-Power Medalion exhaust, JSpec nose badge, mongo's, front strut brace. Matt perf engine rebuild May 2014.
dan_daran
Also cap weir mentioned the fl had revised ecu maps with less aggressive ignition advance and richer cruise/part throttle mapping, maybe to prevent issues
