PROJECT BLACK
Started by ilovejapcrap, June 8, 2017, 20:01
ilovejapcrap
Work has started !
ilovejapcrap
Findings to date:
Need new links from suspension too ARB
Order today.
Going to get ARB powdercoated whilst its off!
Also I have a leaking rear calliper [emoji22]
ilovejapcrap
Forgot to say in pic of new suspension built up I had rubber gator and bump stop on wrong way round discovered this when I took other side apart 🤦🏼‍♂️
It came back off and was done right !
ilovejapcrap
ilovejapcrap
Changed bumper for correct PFL one. Anyone need some fog lights?, think ones cracked etc
ilovejapcrap
I
ilovejapcrap
ilovejapcrap
BCS have done me proud [emoji4]
ilovejapcrap
Front dine also with beaded lines [emoji4]
Got to love predictive text
I love to dine on beaded lines...
(coincidentally, "dine" was autocorrected to "done" for me)
ilovejapcrap
delhusband
Tidy. You could certainly dine off those calipers  :) You not dying to get out on the new shocks/springs and feel all that niceness  :D
ilovejapcrap
Sure am mate but having issue bleeding them. Either lots of air or I've broken salve cylinder.
Just been told by mechanic mate you should try not to pump all way to floor as they can pop a seal.
I wanted to be up and running today [emoji22]
ilovejapcrap
Quick update.
Still have the car.
Soon to have new handbrake cables again as cheap ones are rubbish, midlife hopefully ordered me some [emoji6].
It's due an MOT at the same time
Chilli Girl
Glad to hear you still have the car.  Hope the MOT all goes ok. :)
ilovejapcrap
its started again !!
ilovejapcrap
handbrake replacement has started
tank down
no after pic but new genuine cables now in  8)
ilovejapcrap
moved on to fitting new rad:
ilovejapcrap
forgot to say i replaced another couple of bushes on back arms:
ilovejapcrap
i moved on to front to fit new lower arms and noticed this:
hmm somethings not right with new front suspension ???
suspect top mount is not turning and instead its eating the rubber :(
Ive ordered two new ones from Toyota and will investigate this week
tricky1138
Quote from: ilovejapcrap on May 16, 2019, 07:53
Mine was similar to that, I thought the spring had somehow jumped out it's seat, but now you have got me thinking. Will have another investigation!
ilovejapcrap
just picked up two new rubbers that had been chewed up from Toyota 30 quid for pair.
The old pair had marks from spring and I assumed they came that shape and you fitted them in, but looking at new its not so im wondering if using old ones is the issue
ilovejapcrap
ilovejapcrap
Update time !
The MR2 is MOT'd again :)
things done
1. new drivers front wing liner fitted
2. sorted the chewed up suspension issue new rubbers and top cups fitted, it would seem id not noticed the top cups have a small cut out to sit on shock notch if you will mine did not and as such moved with steering when they should not have !
3. new steering universal joint fitted.
so really starting to come together now.
Only sad thing is i was thinking of the money i've now spent on the MR2 in last couple of years and it adds up ! ! ! :(
just keep telling myself the nicer looking ones will probs need the same work anyway !
