PROJECT BLACK
Started by ilovejapcrap, June 8, 2017, 20:01
ilovejapcrap
ilovejapcrap
so engine is done and back together !
fingers crossed she works  s:) :) s:)
so she has
New style pistons
new clutch
re-honed block
new timing chain setup
all new gaskets
new water pump
new valve seals
valves re seated on head
new auxiliary pulley (mine broke whilst taking engine out)
new injectors
I'm up to about £700 in bits for interest (got discount as have a mate in the trade)
That's a really good price for all that! Hope you're buying your mate a beer.
ilovejapcrap
Step one move engine to car in my special made crate
Step two get under subframe by lying on side on creeper and sliding under , a lot easier without a gearbox
Step three wiggle off creeper and stand upright
ilovejapcrap
Step four lift each side at a time sliding a bit of wood under until at height for trolley jack
Warning this is a mini workout !
ilovejapcrap
Step five with no picture get engine to engine mount on drivers side and bolt loose
Step six call mate wait half an hour slide gearbox under car with trolley jack, remove trolley jack. Slide under car get mate to grab gearbox from above move on to body and push up whilst he pulls.
Step seven start putting bolts in on gearbox and engine mounts
Step eight once all in loose go around and tighten
STEP NINE clean out all crap from engine build and realise you have not fitted new thrust bearing to gearbox ! ! Yep I gotta take it back out tomorrow! ! ( just the gearbox mind )
Hahaha..nice one. Sounds like hard work,but still removes the need for a fair bit of expensive kit
This is brilliant! Makes it a lot clearer for those of us who've never actually seen it done. Thank you!
ilovejapcrap
update the gearbox now has a new thrust bearing took 30 mins from start to finish with help of a friend.
I've still not got the thing to start as of yet !
UPDATE
I have a low compression issue and it wont start don't yet know why  s:( :( s:(  (see other post on low compression )
ilovejapcrap
So I had the head fully re-built (wasn't the issue but looked so much cleaner than my effort and was 100% right)
wish I had a picture as really does look like a new head.
then new head gasket / bolts for a 2nd time and finally
IT RUNS !!!!!!!!!
After much messing around I know have a y reg mr2 with
New clutch
New updated pistons
New piston rings
New timing chain
Fully rebuilt head with clearances checked etc
New pulley
New water pump
New aux belt
New injectors
Re honed block
Uhmm think that's it basically as good as a new engine.
Still stuff to do but big hurdle done
ilovejapcrap
ilovejapcrap
#36
got a new sub frame rust free stripped and powder coated
ilovejapcrap
fitted  : )
ilovejapcrap
Started on the arms
old bush out with ease
Quote from: "ilovejapcrap"
fitted  : )
I hope you filled it with protection first?
ilovejapcrap
#40
you can do it whilst on car take the rubber bungs out and spray in.
but yes I did
Quote from: "ilovejapcrap"you can do it whilst on car take the rubber bungs out and spray in.
but yes I did
I'm going to fill mine with rice over winter, keep it dry, old school...
ilovejapcrap
#42
Quote from: "Call the midlife!"
but yes I did
may be a bit heavy lol
but yes I did
Not tinned rice...
ilovejapcrap
#44
ilovejapcrap
#45
new bushes on painted arms
ilovejapcrap
#46
got to say although expensive I'm loving the bushes soooooo easy to fit no press no messing
Saucy...
Essex2Visuvesi
#48
Everyone loves a nice red bush  s:) :) s:)
ilovejapcrap
#49
Quote from: "Essex2Visuvesi"Everyone loves a nice red bush  s:) :) s:)
Is it appropriate to do a lube joke with this ?
