Sound deadening.
Started by Carolyn, August 13, 2017, 17:38
I finally got round to pulling the bins and applying strips of deadening material to the sheet metal.  I got in behind the carpet on the vertical bit behind the seats and put some strips on there too.  Made a massive improvement.  The cab is much quieter.
I'd been putting the job off, because of the apparent need to remove seats, carpet, trim pieces and console to do the complete job.  Then it occurred to me that I could do the floor-pan by attaching the material to the underside.
I'm going to give the underside a good clean, attach the material in strategic locations, and seal the edges with Tigerseal.  I don't think the floor will know which side it's being deadened from.
lamcote
Sounds like a good idea, what are you using as the sound deadening material?
All on the underside.  Happy with the improvement.
 m http://www.ebay.co.uk/itm/11-Sheets-375 ... 2749.l2649 m
lamcote
Thanks, I will give it a go soon. Did you use all 11 sheets?
Yup - juuussst enough....
Justin.D
Just ordered the same stuff. I've been meaning to get some sound deadening done for a while. This seems the cheapest and if it has the 'Carolyn seal of approval' them I'm happy with that
Planning on doing the doors too - will see if it needs upgraded speakers after
Click for my Readers Ride
m1tch
Also note that if you fit a hard top its also much quieter - was amazed at the difference with mine  s:) :) s:)
Justin.D
Quote from: "m1tch"Also note that if you fit a hard top its also much quieter - was amazed at the difference with mine  s:) :) s:)
Thanks. Hardtop will be fitted for the winter
Justin.D
I have just spotted this sound deadening is down to less than £8 on ebay with free postage. Looks like a bargain to me - get in quick before it goes back up again
Quote from: "Justin.D"I have just spotted this sound deadening is down to less than £8 on ebay with free postage. Looks like a bargain to me - get in quick before it goes back up again
Ordered....thanks.   s:D :D s:D
smarty72
Ordered some too - cheers for the heads up.
current: Astral Black FL
Ex: Forest Green 2003.
m1tch
I found that when I removed the carpet from behind the seats there is a fair amount of extra engine noise - I think focusing on that area might yield a good improvement. I also think there are some spray on sound deadening products for under the car as well. I also noticed a large drop in noise with the hard top fitted.
The Other Stu
QuoteThis listing was ended by the seller because the item was lost or broken.
  s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
Quote from: "The Other Stu"
They only had a very small quantity left.  I was going to order some more in 4mm but it looked they closed their shop....?
