CAN BUS?
Started by mikek, November 7, 2017, 20:26
mikek
This maybe a stupid question but I don't know the answer
Do our dashboards run on the CANBUS system?
How do standalone ecu' s run the dash?
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
This is something I would like to know 100%.
My gut says no.
I think people end up running 2 ECU like I do with the V6.
Krampsnetts ChrisGB Headcase and others will know for sure.
lamcote
Monsi said this earlier this year.
"The guy who tuned my Megasquirt uses Motorsport Electronics ECU's for his "car with engine in wrong place" projects and seems very happy with them. I would check and see if they support the crank and cam profiles for our engines, it's also worth going through the MR2 circuit diagrams and working out how many inputs/outputs there are, and what signals they expect. The standard ECU also controls the dashboard (temperature gauge, Charging indicator, Oil pressure light and bizarrely the handbrake light, I couldn't find any off the shelf solution to this and ended up making a CAN bus adapter for the dash as a temporary solution), and also the immobilizer."
Essex2Visuvesi
When we started looking into the wiring for the Adaptonic Standalone they (Adaptronic) suggested that we keep the stock ECU to run the dash and immobiliser
Mr2 isn't CAN
mikek
Quote from: "shnazzle"Mr2 isn't CAN
So how do you run the dash?
Essex2Visuvesi
Quote from: "mikek"
Adaptronic suggested running the Dash from the Stock ECU
ayresyboy
Quote from: "Essex2Visuvesi"
Quote from: "mikek"
My 2gr has the dash running from the stock ECU
Sent from my Lenovo P2a42 using Tapatalk
1997 MR2 V6
2003 Caldina GT4N
CAN is just a protocol. Cars ran electric dashes long before CAN  s:) :) s:)
ayresyboy
Mk3 MR2 is OBD2
From tinterweb:
CANUSB could be used to read CAN signals from a vehicle by connecting CAN_L, CAN_H and CAN GND to the correct pins on OBD-II connector, but without software to interpret the messages they would be pretty meaningless. So, if you want to interrogate your car, get an OBD-II scanner or scan tool, which uses PID codes defined by SAE J1979.
1997 MR2 V6
2003 Caldina GT4N
Quote from: "mikek"
Keep stock ECU.
Piggyback it off the relevant sensors so it can read speed revs etc.
It does nothing except the dash.
