Rough idle
Started by Nvy, November 27, 2017, 09:56
jonbill
I'm really not sure there's anything wrong  with the idle control - 1500 during warm up.  [emoji736]
900 as you stop when warm. [emoji736]
Drop to 750 after a few seconds stationary. [emoji736]
By all means clean the iac valve and throttle body, but I'm not sure how much will change.
It'll be a duff o2 sensor in the end haha. As usual
I'm with Carolyn, JB and Lamcote.
Mine behaves in exactly the same way.
NVY
In answer to one of your other questions. The Spark plugs you are looking for are
NGK BKR5EYA-11 (NGK2526) Should be correctly gapped straight out of the box.
But good practice to check.
Worth doing anyway as only about £11 delivered for a set of 4. Bargin
I change mine every year.
