Blue PFL V8 conversion
Started by 8thumpers, January 14, 2018, 00:39
8thumpers
Should be ok... used a lot on gt40 reps etc
It only needs one gear anyway!!!
Quote from: Joesson on August  5, 2018, 10:57
That seems a long way for a rod linkage. But, you won't be needing many gear changes with all that torque available!
jonbill
Glad you're still making progress. Keep it up.
8thumpers
Quote from: jonbill on August  5, 2018, 12:46
Cheers mate
s12vea
Some great progress mate. Keep up the good work i can almost hear that v8 running ;)
Ex TTE Turbo
Another one won't hurt  .....
ayresyboy
1997 MR2 V6
2003 Caldina GT4N
8thumpers
Spent a night or two converting the old £56 mig to a euro torch. A vast improvement on wire feed and smoothness.
A little late in the night to really test it, but 1st impressions are good!
8thumpers
The first of the hubs had been built up with ally weld on the you.
Next job is to do the milling down to the required size and see how it fits the shock leg...
MrT
Well that's coming along well. Are you going to heat treat the hub to relieve and restore strength to the welded section?
Tyler
8thumpers
Finally got the first hub in the mill.
I'm v impressed with the weld build up.... you can barely see the joint.
Hold on. Did you build a section of metal using weld?
Is that the equivalent of making car body parts using expanding foam and then trimming it?
8thumpers
Quote from: shnazzle on September 29, 2018, 17:35
Yes !
it's the same process they use for re-profiling cams.
Well I'll be damned....
Quote from: 8thumpers on September 29, 2018, 18:59
Yes !
You cannot insert a mind blown gif...
. This NEEDS a mind blown gif to be inserted here!
8thumpers
Finally got a trial fitting of the 1st rear hub. It looks like it was factory made for the job!
jonbill
Ah that all makes sense to me now, I couldn't picture how that hub went before [emoji3526]. Keep up the good work.
Well that was really lucky ;)
8thumpers
Quote from: Joesson on November  2, 2018, 09:46
Sometimes you have to have an eye for it! Lol
@8thumpers - From your photos I believe you are milling the ally dry.
Have you had any problem with it sticking to the cutting edge?
Paraffin was the cutting fluid for ally, when I was a miller, but that was a while ago.
Hope your "luck" continues ;)
8thumpers
Quote from: Joesson on November  2, 2018, 22:02
Hey
No we did mill it with cutting fluid - applied by hand every so often. Works ok :)
Fingers crossed on the luck!
when I was a miller
Aaaaah this was you the Tony..
@8thumpers keep going fella. Ding Day 19 isn't far away! ;)
Quote from: StuC on November  3, 2018, 00:08
when I was a miller
Glad to see your back @StuC  - and grinding them out ;)
when I was a miller
Only after sprouts eh Tony.
@Joesson @StuC
Quote from: 8thumpers on November  2, 2018, 23:31
Hey
Sorry @8thumpers, I'm sure you know how to suck eggs as well as I do ;)
Quote from: 1979scotte on November  3, 2018, 09:27
when I was a miller
@Joesson @StuC
@1979scotte said"Lanzarote, sunny but windy"
Are sprouts on the menu in Lanzarote?
Any updates on this one? Ding day approacheth....
