Power ranger red
Started by justinread72, March 29, 2018, 21:21
justinread72
So close now can't wait to get the engine in.
Presume you've replaced all you reasonably can whilst the engine is out?
justinread72
Quote from: Alex Knight on September  5, 2020, 14:33Presume you've replaced all you reasonably can whilst the engine is out?
Yes Alex on the tread is a parts list so far. It has had a full overhaul and has a type s oil pump 50 degree vtc gear so future proof.
justinread72
Wiring ! Ran out of tape fml so I am held up
That said I fitted all the super pro bushes and finished the caliper builds.
justinread72
So I had to go to Romania for work for 2 weeks and now I have to do 14 days at home so will be cracking On and after my two weeks quarantine the plan is to to  have a week off work and get the beast running!
Wiring tape arrived so finished than. Engine in this week or I will be disappointed
Once it's rolling I have some paint work to do on my type s civic. Want to give ruby some love also. Want to replicate the pic below
justinread72
 8) all on my own but it's in ! Is this the first k24 in the uk ? If not let me know
I am under no illusion that was the easy bit ! Now got to work through all the systems and get her running then and only then will I build up the suspension as if she don't run then a huge rethink
Could be mate seen the k20 done but not the 24.
Well done.
justinread72
So some new parts on the market Mitch auto parts mounts look great and way better than the innovative rubbish. I had made my own and they are ok but these are tried and tested
For reference these two mounts and the gearbox mount he sells I did not need will swap a k20. For k24 you need a different top mount it's from monkey wrench but only £30
I have also put my name down for drive shafts from Mitches also. Brandon is great he done many swaps. Trust me he is the go to for parts
puma2
#58
 :) this is  some build  and then some more :)
love the effort of your work and your post on here are brillent ;D  ;D
Just wished you had put the the yellow 1 up for sale here :(  :(
justinread72
 8)
Coilovers in Tegiwa had some in stock or most is 12 week wait.! And hel brake lines gona be a busy week !
Also fitted all the new ball joints rear wheel bearings and whiteline bushes to wish bones.
#on rails
justinread72
Quote from: puma2 on October 28, 2020, 14:50:) this is  some build  and then some more :)
Many thanks for the compliments nice to know it inspires others. Yellow car sold quick ! It was was a stunner the red will be better !
puma2
Quote from: justinread72 on October 30, 2020, 10:38
Yes i bet it will be BUT its not yellow ha ha. when the red is done you can wrap in yellow good man
FredyCro
Going the same k24 route as you are, looking forward to updates
IG: optimal_zzw30
justinread72
Quote from: FredyCro on October 31, 2020, 06:23Going the same k24 route as you are, looking forward to updates
Good on you well I can give you a lot of advice so you don't make the same mistake I did.
What engine have you got ? What gearbox ?
justinread72
So a week off work cracking on with suspension and engine mounts and looking also at plumbing it and fuel lines
Wiring loom on the way and immobiliser delete
Brake lines coilovers track rod ends lots of new parts. Images tomorrow as it got dark
Now anyone doing a kswap you must use the Mitch auto parts mounts period they are buy far the best fitting and use all the Toyota mounts to looks very stock and also uses a fourth mount unlike innovative rubbish
Nice work Justin. Keep it up!
justinread72
#66
So I have raised the shifter and I hate the handbrake on these cars and the centre console the handbrake never works well on the three I have owned so for a while I been wanting to do something and here is my relocated handbrake now foot  brake ! It's Toyota so the light switch is the same and this has so much more adjustments so I hope it works.it's of a Toyota Prius
I never liked the gear shift position always to low.
Well happy with how it's turned out. And thanks lockdown where are my brake pads as now I am stuck. But will start on wiring. Coolant lines and clutch line is done
No more "handbrake turns" for you then Justin!
Not sure if I am more impressed by the work you have done on the car or the purchasing of the donor cars!
Keep up the good work as I am really looking forward to seeing the end result.
justinread72
So a good day !
Front suspension and brakes built up and rears just need to connect hand/foot brake, coolant lines nearly done, idiots sent wrong parts. Clutch line done
Fuel line done. Shifter tomorrow, fitted wheel to see how it may look and it's a beast !
Enjoy the images all You cannot view this attachment.
Chilli Girl
Great work Justin, all topped off with a Lotus centre cap, very nice. ;)
justinread72
Waiting for electrical stuff the post is slow !
Airbox is mounted and the ducted goes straight into the side vent perfect
justinread72
Ok so today the starter solenoid fired for the first time !  8)
Anyone doing a k swap in any car use this harness and in my opinion is better than any specific roadster/spyder k swap harness this was £150 and with immobiliser delete came to £240 also that was next day deliver from Cyprus.
The instructions are good and you get to have engine light oil and alternator lights !
I am taking my time on this and learning a lot.
Fingers crossed soon she will fire up !
Also see the badge I am having. As you all know in Japan it's a mr-s well my engine is from and accord type s so you can see how I come up with this and I love it
justinread72
So I have done all the wiring first fix just waiting on a few terminals and this week end I am gona start her !
Justin, this is a properly tidy job.
Fantastic that you've done it all on your own, in a small(ish) garage. Great work that man.
