Gearbox failed.
Started by jhothersall, April 4, 2018, 16:30
jhothersall
Quote from: Nunfa1 on April  7, 2018, 12:49
Replacement gearbox and clutch and it will be fine. Happened to me a couple of months ago, certainly gets the blood pumping doesn't it. :)
Ask the garage how much for a clutch replacement, that is basically the job, then just give them a different gearbox to fit. A LUK or Exeddy clutch should be available for around £75.
Mine is running better than ever now, quieter and more economical, all told job cost around £500.
Thank you I Will ask :-)
KV02 XDJ  - 2002 -  Blue - Black Leather Seats - Chrome Pack Installed - Non-working Air Con - Sony Bluetooth Stereo - Owned Since Dec 2012 http://www.mr2roc.org/phpBB3/garage_vehicle.php?mode=view_own_vehicle&CID=270
jhothersall
Garage called it's is the gearbox 4 1/2 hours work tops and a new Clutch is £80. He mentioned £237 I think that's just labour but if it's less he will take it off. Can anyone help with a gearbox and should I go for a 6 speed ? Ideally about £200 for the gearbox, what are people's thoughts?
Quote from: jhothersall on April  9, 2018, 15:19
Very possible. If you're happy with a 5 speed I think I saw Dick Sloan had one on Facebook. 5spd with LSD.
If not, try either Dick or Dean in the breakers section in the Marketplace
jhothersall
Spoken to D ick and he don't have one. £200 for a 5 speed on Facebook group..
Nunfa1
4.5 hours is what my mechanic quoted.
6 speed will be more work as the shifter will also need replacing.
jhothersall
Ah not to worry, I've been quoted on Facebook enthusiasts group £200 with LSD. What do you all think? Good ?
Quote from: jhothersall on April  9, 2018, 17:07
Good price
8thumpers
I've got a 5 lsd speed box and engine - happy to split if you want it. £150 to you.
I'm in N. Shropshire
jhothersall
Quote from: 8thumpers on April 10, 2018, 08:39
That's good, how many miles has it done and getting it, is the problem. I have been offered one from a 01 at £200 done 90ish...
8thumpers
Quote from: jhothersall on April 10, 2018, 09:19
It's got 82k I think - 2000my
jhothersall
That's good but it's getting it tbh. This one is in Lancaster.
8thumpers
Quote from: jhothersall on April 10, 2018, 10:41
No worries  - hope you get it back on the road soon [emoji106]
Nunfa1
Pallet delivery is around £45. Speak to your garage, you should be able to get sent directly to them, hopefully.
Beachbum957
Quote from: Nunfa1 on April  9, 2018, 16:59
The 5-speed shifter works on a 6 speed.  In some cases, reverse may be hard to get, but placing 2 washers under the bell crank bracket solves that problem.
tomaky
I do have a 40k 6 speed I could sell best I could do is 200+ postage so looking nearer 250
Sent from my CLT-L09 using Tapatalk
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Quote from: tomaky on April 10, 2018, 20:45
Genuine miles.
Car had very little use.
I will vouch for it.
tomaky
Quote from: 1979scotte on April 10, 2018, 20:48
Genuine miles.
It's a steal realistically I'd be chopping at leatst off the price. Last 5 speed I sold was 290 with postage.
Westfield Seiw
Ex - 2003 Sable
jhothersall
Right okay, that sounds good but is there a guide as the garage might not know how to do it ?
tomaky
#43
If they don't know. I wouldn't have them fit it. Comes with the 6 speed gear cage.
Westfield Seiw
Ex - 2003 Sable
jhothersall
I ended up getting a gearbox on Friday night. Was £200 for a 5 speed with 90k on it. I just need one ASAP.. but thank you Otto for the offers.
The clutch is shot at. The garage think the lack of gearbox oil change is at fault. I have the old gear box out it does turn but stiffly... is the useful for anyone? If not it will be sent to scrap.
Thanks for all your help. I should have it back on the road soon :-) James
jonbill
I'd be interested in taking a gearbox apart - whereabouts in the country are you?
jhothersall
Gisburn near Clitheroe but the garage is in Barnoldswick the garage were/are what to know what happened I suspect no gearbox oil change is the reason ...
jonbill
Thanks - thats about 30 miles from me, so possible one evening. Would it need to be collected from the garage during the working day?
jhothersall
8 - 5 the garage is open you can have it they say.
Do you want?
jhothersall
#49
They will keep it for 2 weeks. So much better getting less reves at good speeds and the engine sounds better and running so much better :-) really impressed what a different gearbox and new clutch can do !!!
