Ride height - stock and with coilovers
Started by Nvy, March 28, 2019, 15:37
Nvy
Hey guys,
Do you know the OEM height and alignment? I couldnt find them and i have the TTE springs fitted so cant measure mine. With the coilovers id like to add a bit of height so ideally looking for the OEM numbers or -15mm the most.
Also to the track guys, whats a good start with the camber and toe? I will be fitting MeisterR coilovers with some camber bolts in the rear.
james_ly
Do you find it too low on TTE springs? Normal OEM springs are super high! I've never scraped on the default Meister height.
MR2 gone<br />GT86
Nvy
Quote from: james_ly on March 28, 2019, 15:49
I do not but the track that we have nearby needs a bit more height so nothing will be broken on the car if i go out of it. Thats why i want some more  mm plus :) MeisterR seems to drop at least 40mm in my opinion.
Beachbum957
Toyota lists a measurement from the ground to the center of suspension bolts.  The measurements below are for early models with stock size tires (185/55-15 and 205/50-15)
Front measuring point
Measure the distance from the ground to the center of the front side lower suspension arm mounting bolt (inner). = 204 mm (8.03 in)
Rear measuring point
Measure the distance from the ground to the center of the front side strut rod mounting bolt. = 270 mm (10.63 in)
Meister R are much firmer than stock so for the same height I find they're much less likely to scrape.
There is a thread somewhere about this we had comparisons between stock and tein.
