Project Scope Creep
Started by moca2cv, October 8, 2020, 09:49
puma2
#275
 :) now that is fun 8)
 i can remember doing something like with a lot of cones and i got lost as to which way to go  :))  :))
moca2cv
Quote from: puma2 on May 21, 2026, 06:53:) now that is fun 8)
I went wrong on my first run but the marshals were kind enough to point out what I got wrong so after that I was locked in! SDMC (I don't know about other clubs) number the gates too so it's harder to get lost, but plenty of us have proven that it's not foolproof!
Nothing is so simple it cannot be misunderstood.
moca2cv
Nice little write up from Sevenoaks District MC on Facebook of the Brands Hatch Autosolo and some nice piccies too: https://www.facebook.com/100063456275903/posts/pfbid02UesCxPPhTvLy61wobbZJas5yQXM1qmDBbG5mnmxgiYMtd2BmtGHREgFvSMr3Dbtvl/
moca2cv
moca2cv
I'm no longer on Instagram (although I've left the profile up because I can't bring myself to delete everything!), so that means I have to post pictures here 😁 Here are a couple more from Formula G round 2:
I'm booked in at Kent Motorsport for an alignment on 22 June, and maybe a couple of extra bits while it's up on a ramp, and then on 28 June I'll be at an event at Valence School near Westerham helping to raise money for kids with special educational needs by offering passenger rides! I am looking forward to that very much, and I'm super grateful to SDMC for entrusting me with this important job :)
puma2
#281
 :) what i nice way way to spend time with the kids putting big huge smiles on there faces with a little lap out in the 2. hopefully a good weather day for you 8)  8)
I can remember being out by Porthcawl with a few of us in our 2s and 2 family's with young kids came past and wanted pictures with them with the cars in. iam postive they thought our 2s were some sort of supercar :))  :))
moca2cv
Dropped the car at Kent Motorsport for a few bits. Alignment, new rad, fresh engine mounts and a brake bleed. Just need my silencer to arrive, and to put some sound deadening in, and I'll have a nice civilised race car again :)
You know you're in a good place when you walk in and see this:
moca2cv
Ok, lots done in prep for some events coming up.
- Alignment done. Gone for -2.5 all round, maxed caster (with rotated top mounts), slight toe out up front and slight toe in out back. I know more camber is better on track, but it's miserable on the road, so I'm happy to compromise on that.
- Shiny new rad and BRD rad bushes are in. Temps rock solid even in this heat wave, heater blowing hot, no issues there!
- The new engine mounts are in, too. I went for OEM with poly inserts. Out ones look like the exhaust touched them at some point...
- I also popped a dash brace back in. I tried using an alternative (turnbuckle and rose joints) but that didn't work so stock for now.
- Tightened up the hydro pivot fixings.
- Fitted the rear spacers (fitment on point now).
- Tidied up the frunk and wiring after the rad replacement.
- Gave the car a good clean and a hoover.
- Fitted a sun strip.
- Cleaned the steering wheel.
After that little lot I'm just about ready for a day of autosolo in the sun to help raise some money for Valence School in Westerham :)
puma2
#285
 :) let us no how the day goes hopefully smiley face all around ;D  ;D
good work on the work InProgress  will it ever  end ha ha
moca2cv
A bit slow to update this...
The demo day at AutoSolo was very much a tale of two halves! It was a glorious day, and I got there nice and early. A nice bacon bap, and natter, and walking the course. It was very tight so grateful to have had the hydro! ABS fuse popped, car unloaded, ready to go!
Sadly no passenger on my first run, but at least that meant less pressure on doing handbrake turns. I was slightly nervous as usually in gymkhana we get a morning of practice to get used to rotating the car in the conditions given, whereas in AutoSolo there's no practice. I missed a gate so no time but the handbrake turns were good, happy days.
Runs 2 and 3 I was FLYING. Error-free runs, and 3 seconds faster than everyone else at the lunch break. I think the passengers enjoyed themselves :)
The lunch break I made a mistake. It was hot, and I was out in the sun too much enjoying myself. I got too hot, tired, and dehydrated. I made mistake after mistake in the afternoon and by the end of the day was 12th overall.
I had also developed a nasty clunk when using the hydro. I was under the car after each run trying to figure it out, but to no avail. So I started working backwards through things I'd changed, starting with the spacers. I whipped them off, no clunk! I can only presume that the clunk was the wheel and hub rotating slightly and the studs hitting the locked disc. I've spoken to some drifters and it's a thing... won't be using spacers again for skids.
So a mixed bag. Not the biggest deal as it was non-competitive, but still disappointed that I didn't maintain the lead.
No onboard videos this time sadly, my GoPro batteries did not like the heat, and I didn't get a single recording :/
Lots to process for the next event, a track day at Llandow... to be continued!
moca2cv
There were lots of things I wanted to do before Llandow, but life gets in the way sometimes...
I wanted to address the GoPro issue, so procured a power cable that slots in to the battery slot and plugs in to a usb port. But I also needed a USB port to plug it in to near the back. So I dug out the crimp set and set about piggy backing the cig lighter.
All installed and ready to charge.
moca2cv
The main thing I wanted to do at Llandow was get back on semi slicks. I have a set of wheels with AR1s mounted, but I wasn't confident I'd have enough tread to get home after the trackday. So how to get the wheels to the track?
The answer was pretty simple - just put the stock seat back in! Then I can get one wheel behind the seat, and three on it.
Et voila, practical again 😁
However I had failed to account for the extra bulk of the seat, and the backrest sits on the newly installed USB port 🫣 I'd just have to slide the seat forward a bit.
moca2cv
I don't have any time for more prep than that really, so other than check tyre pressures I'd just have to see how it went. I headed west very early on Saturday morning and arrived at the track just before 8am.
I got the car unloaded and the wheels swapped over, had my breakfast and a chat with everyone as they arrived, an got out on track as soon as possible. It was so good to be out there again! The car felt quick, planted, and I felt like I was getting back up to speed - I'd not done any fast driving since last year, so it felt really good.
I also spent a lot of time in the morning sitting with novices, helping them with lines and mirrors, and it was great to see them progress through the day.
Lunchtime, I rotated the wheels side to side. Bit of a mission as I can't get the jack under the front so I had to put stock wheels on one side temporarily 🤣
Everything else was great, so I fired up the RaceBox for a little bit of data logging. Unfortunately as the day progressed, it got hotter and hotter and the track less grippy, so my times weren't as good as I hoped - I suspect I was quicker in the morning - but the numbers showed I could be pushing a little more for sure.
About 4pm one of the MX5s buried itself in a tyre wall :( There was a bit of a break while they tidied up and attended to the driver and passenger, a very sobering moment.
But not for long - with only 30 minutes left, it was absolutely frantic as everyone tried to get in a last few laps 😁 I snuck out ten minutes before the end and had an absolute hoot.
I had so much fun, I didn't take many photos, but I'll get some on boards up on YouTube as soon as I can.
moca2cv
Here's a video of a few laps of Llandow:
https://youtu.be/_E21t7csyXg?is=OO28-IqusYeMaODt
And a RaceBox screenshot:
moca2cv
Yesterday I did my first grass auto test with Sevenoaks & District MC at Brands Hatch and, as my aunt was visiting, I signed her up as a member, got her set up with an RS Clubman, and brought her along to passenger with me. I'm not competing for points in this championship, so not an issue being in a fun class.
It was an evening event, so 6-8pm, with 6 tests (5 of which were all forwards - phew!) and three runs on each. As with autosolos, your slowest time is dropped, and your score is the total of all runs. You can do them in any order you like, but most pick a test and do all three runs on that before moving on to the next one. I'm a logical person so started at 1.
Unlike the autosolos however, the gates aren't numbered! You can go through or round a single obstacle multiple times and in different directions, and the cones all look the same, so it's an added challenge!
I'm used to this with gymkhana, but not with multiple layouts and no practice, so to make sure I had the routes locked in, I sat back and watched a few runs of other drivers. Once confident I knew the lines, I had a crack. The strategy worked, and I didn't do a single wrong test all evening.
My first run I ran with ABS and no hydro. There was so little grip, it was hilarious! But the PFL ABS is next to useless with all four wheels locked, and a hydro would be useful, so I disconnected the ABS fuse and went out again, this time in gymkhana mode. It was much better!
We had so much fun, even with the face full of dirt every time we turned, that we forgot to check the times until the last test - we were sat in third, but with just a few seconds between us and fourth, so the pressure was on to put in some clean runs. I picked up a cone penalty on my first run, naturally... so I dialled it back a bit, concentrated on being smooth, and prayed it was enough.
And it was! Very happy to pick up another medal, and even happier to give it to my aunt as a little souvenir. I hope she is able to have a go next time.
puma2
 :) love that your aunty was up for this and you had a good day out with her 8)  8)
even better to come home with keep safe medal 8)  8)  nice one :)  :)
moca2cv
A friend of mine who races an MX5 in a sprint series had some issues with his engine, so he was going to take his rally Micra to Gurston Down this weekend instead, settle for last, and at least pick up a couple of points. I wasn't having that. A deal was done, a swap was made...
I got a Micra for a weekend! I felt like a teenager again, it was a lot of fun. I even took it to a wedding, and found a friend:
What are the chances 🤣
Anyway, while I was struggling to get up to motorway speeds, wrestling the vagueness around country lanes, and bump starting the car, my friend was picking up points...
He was up against a Caterham and F Type so was aiming for third place, and that's just what he managed. I believe he was the fastest MR2, too... 👀
It's come back with a couple of battle scars/badges of honour, and a missing rear bumper infill, so will get it patched up and ready for the next event which I think will be Formula G at the end of the month. My new silencer hasn't arrived yet, so hopefully I can get that on too...
moca2cv
#294
Couple extra pics from the grass autotest too. Write up here: https://www.facebook.com/100063456275903/posts/pfbid02kekrU4fhL4eg9aVq4fL5d8s8vybHL47DRyzYjsguStem2Ri2CqZ5LCFrsUb4BQdBl/
Fast and furious style 🤣
Really need to paint the bumper 😅
moca2cv
I didn't make the Formula G weekend unfortunately. It was at Manston, too, and I was really looking forward to having a play on such nice tarmac... on the plus side, I was in Scotland, and the weather was fantastic, so I'll take that.
Since my friend returned the car (fastest MR2 on the day woo, well done Toby!), it has just sat about doing nothing. The battery had gone flat, so I hadn't taken it out. Then one day, I got a knock at the door and a huge box arrived - it was my Zero silencer! Time to find some time to get that on the car.
If you've ever bought an exhaust off Kevin, you'll know that it's about the best value for money option out there. Yes, it's twice the cost of a Malian, but it's made with pukka steel and really, really well too. Everything always lines up perfectly - honestly the easiest exhaust you'll ever fit - and he includes a quality fixing kit including gaskets hangers and bolts as well. Worth every penny.
The old Malian race exhaust came out easily enough through the bottom, it's only small, I just needed to jack up the rear. The rusty bolts were no match for the Ugga Dugga!
New rubbers were the hardest part of the install! But then it was a little Crystal Maze challenge to get the larger box in. A separate rail pipe with v band clamp makes it easier. To make sure it stays where it should, Zero drill holes though the hanger and give you a P clip - no slipping off now!
The final piece of the puzzle was the tailpipe. This was a two person job actually, but only because my tailpipe chassis hanger was in the wrong place from the crash at Llandow a few years back. A bit of brute force to get it lined up and a steady hand holding it in place while I nipped it all up made it a doddle.
Looks good I think!
I've also whipped out the battery and stuck it on the Ctek to see if it's salvageable, put the seat back to my position, and fitted a CG Lock! A present from a friend, these are gold dust these days, and this was brand new never fitted! No pics as it was dark, but it's probably the most valuable part of the car now 🤣
"If you've ever bought an exhaust off Kevin, you'll know that it's about the best value for money option out there. Yes, it's twice the cost of a Malian"
But 4 times better.
Buy cheap buy twice. Springs to mind.
I was very disappointed with the malian.
No regrets with the zero.
moca2cv
Quote from: Ardent on September 11, 2026, 10:26"If you've ever bought an exhaust off Kevin, you'll know that it's about the best value for money option out there. Yes, it's twice the cost of a Malian"
But 4 times better.
Spot on. I feel a bit of a dummy for not getting one sooner, tbh. I have the Zero manifold and mid-pipe, and used that with a Malian twin exit silencer I got very cheap for ages. That became a single exit in the crash, then rusted and broke at the inlet to the can. I replaced it with the race box because I'd stupidly thought that the tail pipe hanger had been lost in the crash. It was not, it was bent out of the way, but it's very much still there 👨�🦯�➡️ Got there in the end!
moca2cv
Since using the car for gymkhana, I've been thinking of ways to make the car work for me on the road, on track, and for skids. The car has to be good at all three, and although it's a master of none, the driver is the weak link so I'm ok with it.
However, one thing you have to do for gymkhana is disable the ABS so you can use the hydraulic handbrake. It's very simple to pop a fuse out - you don't need to disconnect the battery or anything, popping the fuse back in enables ABS. So... it should be switchable right? The only internet reference to doing this was a single comment by Danny DC2 that he'd fitted a switch. No elaboration unfortunately. This should be fairly simple on its own.
I also got to thinking about the power steering - our steering assistance varies by speed, with max at zero mph, tailing off as speed increases. This makes sense on the road and on track, but for gymkhana wheel speed is often considerably higher than actual speed, causing inconsistent steering. If I could make the PS ECU think the wheel speed was zero, I'd have full assistance all the time. And if I could put that on a switch... you see where this is going.
So I hatched a plan to install a 3 position switch that could select different modes: road mode, ABS off, and gymkhana mode. I gathered parts, and opted for relays so the circuits could fail closed. It was a good time to also tidy up some wiring - I'd been powering my gauges off the radio harness, so could take the IGN+ and ground from there easily enough. I had got rid of oil pressure and temp, so just AFR left. I wanted to relocate that to a heater vent to avoid having a gauge pod in my line of sight.
So out with the sub loom and on to the wiring...
Honestly I had no idea what I was doing; or indeed how to do it. I made a lot of mistakes and had to redo things a few times but got there in the end.
The switch mounting was very easy - hole in a blank.
Once it was all wired up, off to pop it all in the car. This is the long bit... routing was hard and lots of do overs later I finally got roughly where I was happy being.
If you're ever thinking of vent mounting a gauge, don't bother. It's a pain.
Switch looks very at home. I just need to split the right wires to switch. Job for tomorrow...
moca2cv
#299
Didn't get round to sticking my head in the frunk today, but did clean my steering wheel.
I wear gloves when I drive on track, but not on the road, or when I'm working on the car, so I give it a brush with some suede cleaner fairly regularly. But as I had some time, I thought I'd get busy with some Fairy to try to get the oils out.
First thing, remove the wheel from the boss. I can do this from the comfort of my utility room 😁
Warm water and Fairy is what I'm using to scrub.
Get a microfibre and really give that wheel a scrub. Rinse the cloth, wring it out, scrub, repeat.
It didn't look bad to start with but look at that water 🤢
Dry with afresh microfibre, brush with a stiff brush, let it dry.
Job done!
ETA - it's not perfect. It probably needs a lot more work to get the matting out completely. But also... it's 12 years old, on a track car, it gets abuse. This will do :)
