LED Daylight Styling Lights
Started by Smithy, November 5, 2020, 11:57
scm2004red
Quote from: MisterK on November  6, 2020, 15:06Find the live wire (blue I think) for the wipers & simply scotchlock onto this.
Please don't, those things are an abomination, if you must mess with wiring do it with proper connections and fuses if required.
MR2 Red Edition 2004
Porsche 924 1984
Quote from: scm2004red on April  6, 2021, 21:24
Can't you cut the wires and just superglue them together?😉
What is the issue with using them?
SV-3
Quote from: 1979scotte on April  7, 2021, 07:52
There is no issue.
You know what they say: "A bad workman..." or some variant thereof.
Weren't these originated by 3M?
Eclectic - not electric
Sony WX-920BT
"Hardtop Cognoscenti"
"Stock Cubed"
"AirCon Aficionado"
"Keeper of the Beeper"
Quote from: SV-3 on April  7, 2021, 10:00
There is no issue.
Yes they're a 3M product.
So like everything else when used improperly they fail?
SV-3
Quote from: 1979scotte on April  7, 2021, 10:08
There is no issue.
11th Commandment ;)
Sony WX-920BT
"Stock Cubed"
"AirCon Aficionado"
There is no issue.
In the industry that I worked in where multiple wires multiple metres long, carrying power or control voltages enclosed in trunking or conduit it was not good practice to have any joins because of the problem of locating a loose joint/ fault.
Terminations in control panel or switches though were typically by a screw terminal so nothing fundamentally wrong with a "chocolate block" but any screw terminal can be susceptible to loosening by vibration and a crimped joint is preferred in that case.
Quote from: SV-3 on April  7, 2021, 10:10
There is no issue.
11th Commandment ;)
As with many things a product is designed, developed and marketed and accepted on it's virtues but then " someone else" decides they can make it cheaper and they do. But the quality is not the same, typically less and therein is the problem. A 3M connection block I am sure is a thing of beauty, but a similar product made by a Christmas Cracker  novelty manufacturer will not be so good.
Smithy
Quote from: paulj on April  6, 2021, 20:48Have a look at this how to post https://www.mr2roc.org/forum/index.php?topic=65007.0
There is a photo of the wiper motor wires
Legend. Thanks Paul
03 Astral black MR2 OEM+
Smithy
Finally finished the install of my DRLs. Thanks again everyone for all the help identifying the wiring. They are on during the day and dim with the headlights on.
Chilli Girl
Well done James, great job. ;D
Newbie57
#36
When I thought about doing I was going to use a piggy back fuse on the cigarette lighter then use a piggy back on the dip fuse to an nc relay. Fitted the Chinese led fogs with DRL but not connected the DRL yet
Smithy
This is the final result
