Relíable OBD2 dongle?
Started by Petrus, November 13, 2020, 18:41
Because two bluetooth thingies stopped bluetoothing, bought a handheld cable reader. Ok to reset codes but I réally liked the extra data from the various car´s sensors through the Torque Pro app.
Would like to buy anóther dongle but am loath to have it stop again way to soon.
Are there any more reliable offerings?
OBDLink LX
Expensivr but I've been very pleased
How much have you been paying theyre so cheap only like 3 quid.
Quote from: 1979scotte on November 13, 2020, 19:21How much have you been paying theyre so cheap only like 3 quid.
You´l be shocked about LX then ;-)
I was looking at VGATE as intermediate.
Bossworld
The ELM237 clones are often cheap crap (I've got one), mine doesn't work with the recommended ELMScan Toyota app and certainly doesn't do any ABS stuff.
Supposedly the Carista dongle for £25 on Amazon has good compatibility with other apps but they notably don't claim support for our cars on their own app website.
I've got about 4 of thr 3 quid ones in my garage.
All work.... Sometimes to most of the time.
The LX always works, is faster, and I can leave plugged in without it costing me my battery
Quote from: shnazzle on November 13, 2020, 19:34
Still; can´t find one below 85€ incl. shipping.
I've had several of the cheap elm clones and for the money they've worked fine for torque on android
Quote from: 1979scotte on November 13, 2020, 20:00I've had several of the cheap elm clones and for the money they've worked fine for torque on android
Mine worked fine for the money too (torque android) but I want one working better for a bit more ;-)
If possible with stand-by like Shnazzle mentions.
Looking at Vgate for 30€.
The specs say it also logs data but maybe I misread that. Would be véry informative.
Coming with 2 year warranty is nice too.
What the heck... pushed the button. Shoúld be here before december.
Will keep you posted.
It can't log any more data than Torque Pro can. Remember that :)
And the refresh rate for the data on these ecu is sh1t
Quote from: Petrus on November 13, 2020, 21:25What the heck... pushed the button. Shoúld be here before december.
Lockdown boredom strikes again.
Quote from: shnazzle on November 13, 2020, 23:45It can't log any more data than Torque Pro can. Remember that :)
Thanks, am aware.
It is not for engine tuning purposes.
Part curiosity, part ´boredom´*, part hoping to get data I con use for the suspension.
Am very curious what centrifugal forces and brake info it registers.
O, and the intake temp ;-)
* yes, confinement in the municipality is increasingly weighing as I úsed to communte between to loves so my brain is trying to escape from my head!
Anyway the plug in is one of the very few ´add ons´ which add no weight
BahnStormer
I always just got those little ELM327's off amazon... for using with TorquePro + ToyoSys... one works perfectly (£10) https://www.amazon.co.uk/gp/product/B014WHK27W/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 and I had another previous £7 ELM327 from my other car - that also worked in the MR2, but throws an ABS fault if you leave it in the car when you switch it on... works fine if you turn start the car first, then plug it in.
Note this only works with Android bluetooth - Apple has the required bluetooth features disabled (until they come out with an "i"OBD2 dongle)....
The OB2 Vgate...
I could not get it sorted with Torque. Tried the propietary app and nogo either. It already went wrong with no green led lighting up. It flashed, like the bue and then only red.
Tried all I could think of, nogo.
Had to wait till modern tech savvy son was here for a few days.
He now is so...
It finally works BUT when it is connected before switching on contact it all goes haywire; all leds flash and the abs check light on the dash flashes.
The only way it gives data to my phone is with the proprietary app and with the dongle put in after makinging contact, then connect with the phone, then start.
Pfffff.
The free version of the app is piddle poor. Luckily it does give inlet temp :-)
Another perk is that we checked the connections with the port and for that I took the plastic panel under the steering column off.
Basically out of sight and with its only direct function being the support for the port, I left it off. It does weigh 403 gramms.
Iain
May i jump in and ask what the difference/benefits are between using a dongle with an app or a standard hand held plug in reader?
Far more detail with the dongle. And (if you must) real time data as the car runs.
A reader just gives you codes - an app will give live readings of fuel ratios, timing, misfires and stuff!
Oh, that's me now and then. Do like a bit of real time data. Esp fuel trims.
And you can record it for later analysis
Quote from: Ardent on February 23, 2021, 18:49And you can record it for later analysis
That was my goal. Seems it will not work, but some real time yes.
Iain
Quote from: Carolyn on February 23, 2021, 18:16Far more detail with the dongle. And (if you must) real time data as the car runs.
