Reusing piston rings.
Started by Call the midlife!, February 1, 2021, 13:21
The mains don't look too bad in general but as I was expecting to be fitting new ones I probably wasn't as gentle pulling them out as I would've been if I'd planned on reusing them so I've probably killed them anyway.
The crank has no signs of damage from the 2 damaged conrod bearings but does look a bit rusty so I'm thinking it's been sat without oil for a length of time, as I only washed it yesterday tea time.
I don't imagine the conrod bearings were damaged by turning it by hand with an empty sump, there was still an amount of oil on the surfaces of the engine.
If you kept track of which housings they came out of - I'd re-use those.  They look fine.
Looks like there's a bit of pick-up on #1 rod journal.  No biggy.
I've only given them a light spin with some 1500 grit to clean them up, I might give that one a fraction more but as you say, it's not that bad.
Everything was bagged and tagged so I know what goes where, the only one I'm worried about is the one that got a little bit dogged when I picked it out but it's a dint rather than a raised burr.
Some unusual markings on the cylinder head...
