Twang!!
Started by steveash, March 8, 2021, 11:31
Steve, even if your question has been answered, we still expect you to check all the suggestions above!
Iain
Well there we go, turns out it was brake related! 😂
Quote from: Gaz mr-s on March  8, 2021, 14:01Yep, I've heard it from 3 or 4 of them.  In the last couple of years the car was outside & on flat ground, so the handbrake wasn't usually applied. I would reverse, then after a few yards going forward, hear the noise.
Mine does exactly the same. Perfectly normal. Part of abs system.
Bossworld
Quote from: Iain on March  8, 2021, 20:52Well there we go, turns out it was brake related! 😂
Yeah, sorry to burst the bubble :) I always used to be overly sensitive to any noise coming from my cars hence I've looked into this one before - https://www.mr2roc.org/forum/index.php?topic=65168.msg764723;topicseen#msg764723
steveash
Quote from: Topdownman on March  8, 2021, 20:52Steve, even if your question has been answered, we still expect you to check all the suggestions above!
Don't worry, I'm already thinking of pulling the fuse for the ABS to see if it goes away. If it doesn't I'll be going round the car with a plectrum looking for things to twang!
Zxrob
Quote from: steveash on March  8, 2021, 11:31Shortly after pulling away out of my drive, my car makes a rather entertaining metallic twang noise. It doesn't sound too worrying but it happens almost every time and only when the car is moved after starting from cold. My best guess it is steering related.
Anyone heard of this before??
I have the same noise, only happens when I first pull away, put mine down the the clutch pedal assembly(spring), could obviously be wrong though,doesn't happen beyond first pulling off
Rob
Adventure before dementia 😁
Halls
Ha! Mine does the same, i was starting to worry it was something wrong.
I guess I should worry that I don't hear this....
Also. If you happen to sit in the car for a while after stopping. You might hear whatever it is un twang as well. I have, but no time reference as to how long.
