Dastek pnp connection for mr2 mk3
Started by Rallyeluke, April 7, 2021, 21:07
Rallyeluke
Does anyone know the correct way to attach. I bought one but I am at loss as to how to do it
Regards lucas
andyroo104
You have to remove the passenger side rear bin or both if easier to access the ecu behind, then drill out the security bolts unless you have the correct piece to fit the bolts, disconnect the factory ecu and refit the Dastek. Of which will probably need to be mapped to suit your car mods if any.
Rallyeluke
I think that was where I was going wrong. I will get the correct torx security bit tommorow and then remove the black bracket to uncover the additional 2 ecu plugs then hopefully I will be able to connect the pnp harness.
