K swap and power steering
Started by Bullit, May 8, 2021, 12:47
Bullit
I know this is going to be really niche but i'm trying to finish off my K swap. The power steering pump now comes on with the ignition in position 1, I can't remember if it did this before. The pump is that loud i initially thought it was the radiator fans.
Has anyone had any experience with this ?
@Bullit
I've recently cleaned the PS motor and changed the fluid with help from:
https://www.spyderchat.com/threads/ps-light-power-steering-problems-try-this.50843/page-2#post-1226761
https://m.youtube.com/watch?v=ElmEb6PKZ50&feature=youtu.be
Whether either will reduce the noise your pump is making I know not but it just might and there is little else to do with the pump.
It was the same behavior with the 2ZZ swap. I wouldn't worry about it.
Quote from: Dev on May  8, 2021, 13:51It was the same behavior with the 2ZZ swap. I wouldn't worry about it.
Same here. PS pump works with ignition on and engine not running.
