E10 versus E5 fuel?
Started by BARNPOT2000, August 9, 2021, 08:48
BARNPOT2000
So, the government website says all Toyotas from about 1998 are fine to run on the new E10 fuel all but for a couple of Avensis models... do we trust them 🤔?
TF099 silver
Quote from: BARNPOT2000 on August  9, 2021, 08:48So, the government website says all Toyotas from about 1998 are fine to run on the new E10 fuel all but for a couple of Avensis models... do we trust them 🤔?
No. But they're right
Will it run on it. Yes.
Optimally. No.
A few threads on this subject. Worth a read.
Some unhelpful posts removed.
If a topic has been covered before, a link to that topic would be more helpful than a sarcastic comment.
Quote from: shnazzle on August  9, 2021, 16:36Some unhelpful posts removed.
Or people could use the search to see if it's been covered before.
This was recently covered in extreme detail.
Have you lost your sense of humour?
Quote from: 1979scotte on August 10, 2021, 13:18
Clearly :)
The search on here is known to be a problem, that's also well-documented and an issue I will address at some point but in the meantime, best we help each other out a bit.
tomato
Just use shell V-Power or something similar 😀
