Ebay wishbones
Started by BARNPOT2000, October 29, 2021, 22:38
Gibla
They look the same as these https://www.ebay.co.uk/itm/193021466891 which I can definitely vouch for as good replacements
2001 Dark Green MR-S (6R4)
BARNPOT2000
Quote from: Gibla on October 30, 2021, 14:46They look the same as these https://www.ebay.co.uk/itm/193021466891 which I can definitely vouch for as good replacements
Thanks for the confirmation, much appreciated.
TF099 silver
Smithy
I would like to change mine over while I undertake a suspension refresh. Are they easy to swap over? Would I be able to reuse the original bolts etc.
03 Astral black MR2 OEM+
Quote from: Smithy on November  2, 2021, 14:22I would like to change mine over while I undertake a suspension refresh. Are they easy to swap over? Would I be able to reuse the original bolts etc.
The vertical bolts can be a bit difficult.  It also depends on whether it's got the facelift 'handling package' on - because that has to come off to do the job.
Smithy
Thanks Carolyn. yes a face lift car so the under brace needs to come off? anything else to think about? I have new ARB links to swap over too.
Quote from: Smithy on November  2, 2021, 14:57Thanks Carolyn. yes a face lift car so the under brace needs to come off? anything else to think about? I have new ARB links to swap over too.
When you get it up on jack stands (as high as you can!) have a good look at the job, give everything a generous dose of Plusgas, let it soak and just be patient as you do the job.
I've always done that job on the lift, I don't think I could manage it lying on my back.
Smithy
Thanks Carolyn. I have probably have left it too late to work outside in the cold under jack stands, but we may get some bright if not chilly weekends.
