Front chassis rails
Started by BARNPOT2000, April 26, 2022, 09:21
Sorry, had to remove the last post to avoid potential copyright issues as it's a page from the BGB.
Quote from: BARNPOT2000 on May  1, 2022, 16:18Just on the verge of reinstalling the chassis box sections, do you remember what torque the bolts should be tightened up to please? I believe the long one through the wishbone bush is 73 Nm so maybe do all up about the same?
The long one is 73. The other 2 are 75. As per the unknowingly posted page from the bgb.
McMr2
Sorry just picked this up. Looks like others have stepped in!
2004 Silver. Stock(ish).
BARNPOT2000
Quote from: Ardent on May  1, 2022, 19:39The long one is 73. The other 2 are 75. As per the unknowingly posted page from the bgb.
Thanks, just to check, are you saying the 75Nm torque settings are for the other wishbone connections? I was also after the torque settings for the various bolts that connect the box sections to the car bodywork. Sorry if I'm being a bit dim 🙄.
TF099 silver
Re just the box section.
3 bolts. The long one as you say. 73.
 The other 2 box section. 75.
Quote from: Alex Knight on April 30, 2022, 22:42A friend of mine made one for me, as Toyota have discontinued the bracket I think? Or it may have been a gazillion pounds from Mr T.
Either way, it's stainless steel. Should last a lot longer than the OEM part!
That's a nice friend to have!
BARNPOT2000
Quote from: Ardent on May  1, 2022, 21:29Re just the box section.
Thanks Ardent, looks like the FL version of the box section is a slightly different shape and has a couple of extra bolts 👍.
TF099 silver
