Drainage
Started by Anonymous, May 26, 2005, 09:30
Can anyone tell me if the material where the drainage holes are, able to be replaced or is it part of the hood? I know some parts are attached by velcro but what about that actual piece where the drains slot into?
Cheers,
Viggs
i've got to pass on wether its part of the actual hood, but a decsent repair/manufactuerer shop for hoods should easily be able to do any repairs for you
Excellent Stuff!!
Thanks for that! Any idea what all the white bits are on the drivers side part?  I take it the little spout piece is the underside of the drain?
Cheers,
Viggs
Quote from: "Viggs"Thanks for that! Any idea what all the white bits are on the drivers side part?  I take it the little spout piece is the underside of the drain?
little white bits are more than likely attachment clips and yes the the little spout will be the the part that attaches to the drain into the compartment behind the side intakes. Outside of that i havn't got a clue, sorry, never done one before so take some piccies and let us know how you get on
