E153(MR2 Turbo) - Gear Box Swap - Plus other Options
Started by Gaz2405, January 12, 2023, 11:53
Nvy
Quote from: Gaz2405 on January 13, 2023, 19:56Best I've found is RRR at £840
Maybe its worth it to check some Ausy sites as their currency conversion is quite fine to eur or gbp. Ill try to ask a friend.
Mark A
Can't help but think a complete VAG 2.0 TSi and DSG swap might be the cheaper option for 400bhp and a sequential gearbox. Engine mounts and driveshafts are already available in the UK, another £1k get you a proper LSD.
I'd be interested in people views?
Mark
Gaz2405
Quote from: Mark A on January 15, 2023, 21:03Can't help but think a complete VAG 2.0 TSi and DSG swap might be the cheaper option for 400bhp and a sequential gearbox. Engine mounts and driveshafts are already available in the UK, another £1k get you a proper LSD.
Mark
Whilst there's been quite a bit of work done by Stav etc I don't think the full swap kit is quite there.from what I've seen.
400hp will still need rods and a few other bits.
If I'd have not gone built 2zz when I did so, I'd have probably gone down the 1.8t route.
Ecumaster also has built-in dsg control. Has had for a while.
So, that should be an easy one for you.
Gregg at RRR has done it in a few cars, and that was a few years ago. Probably done a handful by now.
Mark A
I was referring to the 2.0T EA888 Gen3 engine which seems to be good for 400 bhp with a remap.
