Failed MOT - Offside Rear Parking Brake "Inoperative"
Started by Dagnet, May 17, 2024, 19:24
Quote from: Dagnet on May 22, 2024, 17:16Looks like the old caliper had a partially seized piston - the new one travels a lot more. Lubed the cables as well and it has passed the MOT. Got a spanner trapped between the dashboard and the windscreen in the process...
Well done!!  Result.  That spanner should be fun. ;D  ;D
Quote from: Dagnet on May 22, 2024, 17:16Got a spanner trapped between the dashboard and the windscreen in the process...
That is some going.  :o
I pray thermal movement does not have a joker to play.
The pistons can get very tight in the caliper, regular movement/ use likely "eases" that situation.
Maybe a magnetic telescopic type recovery tool will help retrieve the spanner.
