Lower steering UJ
Started by steveash, June 12, 2024, 14:38
steveash
My steering feels heavier than before and as I already had all the bits in stock I decided it was time to fit a new steering UJ.
Bolts at each end removed, plus gas liberally sprayed. Clamps levered apart but the thing doesn't want to move, despite the clamp appearing to open with a twist of a screwdriver. Any ideas? Or should I just take it to someone who knows which end of the hammer to hold?
J88TEO
Have you loosen the joint at the steering column ( inside the car )?
steveash
Quote from: J88TEO on June 12, 2024, 15:19Have you loosen the joint at the steering column ( inside the car )?
Yes, took the bolt out completely and waggled a screwdriver in the clamp. I could feel a little play in the steering wheel with this one undone so it should be loose.
J88TEO
At the rack end, use a small hammer and give it a few good blow upwards. This should move the joint.
steveash
Finally managed to do it. I removed the upper UJ to check if this was the problem but it moved freely so I went out and bought a heat gun and carefully warmed the UJ around the spindle and it came off with some hammering.
It actually wasn't all that corroded but I suppose after 20 years together they really didn't want to let go.
