Misfire intermittent / coolant leak
Started by H2zzMRA, November 8, 2025, 18:19
H2zzMRA
So mr2 Ben have managed to get hold of denso coil packs- from Japan- 7 day lead time £110 each
Apparently only 10 left in stock in denso Japan
At that price, I wouldn't.   Autodoc have them. (according to website)
If you bought a cheaper one on ebay.....say Lucas, in the unlikely event it didn't work, you'll get your money back no problem.
Quote from: Gaz mr-s on November 20, 2025, 18:38At that price, I wouldn't.   Autodoc have them. (according to website)
I got a refund from Autodoc for some suspension (rubber) bushes that I changed my mind about. You pay a nominal amount extra for a no quibble return. Reasonably straightforward but slightly long winded.
NB I got Suoerpro bushes from TCB.
If mr2Ben can buy them from Japan and sell in UK for £110 each, surely that means that they are available via the Japan dealers that I've read about on here.
£440 seems an awful lot of money to my mind for such items.
As Gaz above suggests:
https://www.ebay.co.uk/itm/357673240639?_skw=Lotus+Elise+2zz+DENSO+Ignition+Coils+OEM+Toyota&itmmeta=01KAHK4TMBPZZS0NQ88MJ3W1EE&hash=item5346fc883f:g:2DYAAeSwUBVo18gu
Quote from: Joesson on November 20, 2025, 21:19https://www.ebay.co.uk/itm/357673240639?_skw=Lotus+Elise+2zz+DENSO+Ignition+Coils+OEM+Toyota&itmmeta=01KAHK4TMBPZZS0NQ88MJ3W1EE&hash=item5346fc883f:g:2DYAAeSwUBVo18gu
I wouldn't buy that make.  Maybe unlucky, but I had something by Lemark before.... an O2 sensor I think.  It worked for a very short time & died.
NTY (NGK)
Magneti Marelli
Bosch
Lucas
been around for years.
They might all be made in the Chinese factory though....... ::)
Quote from: Gaz mr-s on November 20, 2025, 21:55I wouldn't buy that make.  Maybe unlucky, but I had something by Lemark before.... an O2 sensor I think.  It worked for a very short time & died.
NTY (NGK)
Magneti Marelli
Bosch
Lucas
How about these?
https://www.monkeywrenchracing.com/product/toyotalotus-denso-oem-coil-assembly-1-2zz-ge-new/
They'd probably charge at least $25 to send it.   The names I said above are all on ebay......
IloveCurbs
Quote from: Gaz mr-s on November 20, 2025, 22:46They'd probably charge at least $25 to send it.   The names I said above are all on ebay......
For sure other suppliers and/ or manufacturers are available at rather less than £110 an item!
