SMT leak, from gearbox or hydraulic?
Started by rajid, March 30, 2026, 16:01
Quote from: fawtytoo on April 18, 2026, 17:59Not sure where you got that from. The system is hydraulic and the battery being weak isn't an issue.
I thought I had read that in here somewhere. If not then the joys of the inter web.
In the same way a weak alternator lights up the dash like a Christmas tree. The inference was a weak battery does not provide quite enough umph to pressurise the system or something like that.
fawtytoo
Quote from: Ardent on April 20, 2026, 22:23I thought I had read that in here somewhere. If not then the joys of the inter web.
Ah! You're probably referring to the hydraulic pump unit. It starts when you open the drivers door. Yeah, if the battery is low, it never pressurises. I understand you now.
Life Driving is about the journey, not the destination.
rajid
Quote from: fawtytoo on April 20, 2026, 23:15Ah! You're probably referring to the hydraulic pump unit. It starts when you open the drivers door. Yeah, if the battery is low, it never pressurises. I understand you now.
That's quite interesting as I'm not sure if I am right here
but mine sounds like it starts pressurising when it's turned to ignition position 2, runs for about 10-15 seconds and then I start the car and engage gear.
I have started the car quickly before and tried to engage gear, and realised that it doesn't want to. Have learnt the habit of relaxing and letting it do its thing before starting up the car very shortly after!
Quote from: rajid on April 21, 2026, 01:37That's quite interesting as I'm not sure if I am right here
As fawtytoo said, you should hear something come to to life when the drivers door is opened.
Monkey Relish
For the "is the Toyota SMT fluid really brake fluid ?" debate, this is from the attached safety paperwork from an OEM TOYOTA SMT fluid container.
Brake fluid it is.
Mr Relish
fawtytoo
@Monkey Relish As the SMT was developed for the Australian market, you know what you're talking about.
Quote from: Ardent on April 21, 2026, 07:01As fawtytoo said, you should hear something come to to life when the drivers door is opened.
You will likely have seen that it is said that the SMT system was developed by Luk England.
From this link you will see that Luk England is located in NW London!
https://www.gdl-uk.com/brands/luk/
