HELP: with a Broken SMT (of course!) - North West London
Started by rajid, Yesterday at 21:52
rajid
The inevitable has arrived
Car started playing up one day, after mechanic had checked and topped up the fluid.
Not sure what exactly was done or what caused it, but since the fluid was played with, the car never changed the same.
Drove the car for a few hours thinking nothing of it, eventually ended up close to home and the car was having issues going into each gear, missing some, getting stuck in some, and other general transmission related issues (clunks, flashing gear indicator, non starts, etc)
Now at the point of needing an expert to check it out and see if it can be fixed.
I think the car is now not starting, and mechanic has taken a look but hit a brick wall.
Car is located North West of London
Is there anyone with the expert knowledge around this way that can check it out. Not expecting a fix for free, happy to pay for your time and towards any solutions to the issue/s.
With a basic code reader, the following codes popped up on the first day of problems. It may or may not have more/less codes by now after it's been played with by the mechanic.
P1646 transmission control ecu malfunction
P1647 CAN communication malfunction
ECMECT (engine and ect)
Hoping someone can help this car, rather than it going off to a scrapper !!! :'(
as mentioned in your other smt related threads there have been mention of at least 2 good sources of smt youtube videos.
From your codes alone seems a communication error. is the info being sent? is it being received?
Matter of logical fault diagnosis.
I don't have one, but did repair one after it came back 'dead' from a garage.
I don't like pushing people away from this site, but your best source for help is the Facebook Spyder SMT page.  https://www.facebook.com/groups/656921144477464/ There are a few on there that can answer anything.
To diagnose it you really need Techstream, - you'll get help on there as to how to get it.
fawtytoo
The car not starting means the gearbox is not in neutral. I have a list of possible SMT error codes and P1646/P1647 is not among them.
I can only guess without seeing your car, but unless you have an SMT fluid leak that's leaked over the SMT sensors, you must have a faulty ECU.
Is it possible that your soft top drainage pockets have gotten clogged up at some time, and water has poured over the ECU?
I just think that, just because it's an SMT model, you're focusing on it being an SMT fault when it might not be.
Life Driving is about the journey, not the destination.
