Hot starting issue
Started by cptspaulding, Yesterday at 14:28
cptspaulding
Patsy's 2000FL, 81K miles has developed a hot starting issue.
I've not had a borrow as yet to check for myself but Patsy describes the symptoms as follows...
"If you get the engine to running temp, no need to rag it, just a 10-15 mile run... Get it over 50mph. Stop. Try to restart immediately; it won't start.
Try more than twice to do that , it's like the battery is dead (it's not). Let the car get cold again, it starts like there was never a problem."
She also reckons she can smell something hot.
Over to the mr2roc hive mind for likely culprits, please.
Starter motor dying?  Smelling hot brushes?
Idle air control is my bet, or it's misreading temperature due to airlock or thermostat
Edit: re-read the post and missed the part about it not even cranking like the battery is dead. That's definitely not IAC.
Just for laughs have a look at the power connector to the alternator. It has a plastic cover.
@cptspaulding
Poor connection at battery?  But I bet it's the starter motor.
cptspaulding
Thanks.
Won't be at the battery. I've already changed the battery because, well, someone had been speaking to AI & wouldn't listen to me & ordered a new battery anyway.
 I'm going to try & do a couple of tests with my multimeter at the weekend.
