Gauging Interest- Replacement cover for lever release
Started by Anonymous, July 6, 2005, 00:16
philster_d
#50
OK OK I have weakened.
Ordered.    s:? :? s:?
/Philster.
Quote from: "Markyboy"Word of advice people. Don't use UHU, as when you brake if flies off into the windscreen. Yes I am speaking from personal experience!!
Soopaglue works MUCH better   s:oops: :oops: s:oops:    s:oops: :oops: s:oops:    s:oops: :oops: s:oops:
If you use the Clear silicone sealant (RTV), or blue tack, it (the plate) will not come off by itself. Don't try a shortcut, because it probably won't work. The RTV can be removed at a later date and does not hurt the pull plastic. All around the best way.   s:) :) s:)
