Ariel
Started by Anonymous, October 3, 2005, 10:47
anyone got a standard ariel they dont want as mines has been bent??
Jigwar
Usual responses will point towards breakers jard, or Adam (JapGT300), for replacement parts.
Or more specifically in the case of the stock aerial, quite a few people might have one lieing about if they have replaced it with the short antenna, because they are of the opinion that the stock aerial gives the car the look of a remote-controlled car when up!
If you are of the same opinion, the short antenna is available at the mo over on spyderchat, costs about £70 to get the antenna and conversion kit shipped over. Conversion looks a bit of a fiddle!
Steve
Jigwar
Past: \'51 plate
Present: \'06 plate TTET\'ed
peppyuk
Anyone have any photo's of these or any other's they have fitted?
Never been happy with the wind noise but now I've killed it I'll have to replace it sometime soon.
\'In a state of mental numbness\'
you can buy just the mast part of the ariel for £30 from MrT if that is any help
Ernie Ball
Quote from: "peppyuk"Anyone have any photo's of these or any other's they have fitted?
Here's the one I just fitted today (though that's not my car):
A guy named Lord Takuban over on Spyderchat sells them, though he doesn't have any at the moment.
I think it looks a lot better.  I couldn't stand that giant whippy aerial, especially since it has to be up any time I had the stereo on, whether listening to radio or not.  Reception is slightly degraded with the new antenna, but I only ever listen to the news on the radio anyway.
philster_d
i fitted a switch to the remote aerial, so i can choose
that said I would like one of these.
Some sports cars have 2, 1 fitted either side, my transmition principles education tells me this would be better because they can remove more of the rubbish, by comparing themselfs.
I wonder has anyone done this ?
peppyuk
Quote from: "philster_d"i fitted a switch to the remote aerial, so i can choose
I was going to fit a switch but haven't found a switch I liked yet! If I had fitted one already I wouldn't have destroyed it driving through a fallen tree, as luck would have it I haven't done any other damage to the car, just the aerial.
Quote from: "spgreen"you can buy just the mast part of the ariel for £30 from MrT if that is any help
Are these easy enough to fit?
they are not difficult
First off you need to remove the wheel then the plastic liner to the wheel arch. Then undo the bolt that secures the ariel in place and unscrew the silver part of the ariel on the top of the wing and the ariel will come out.
Unscrew the gold screws on the ariel unit and remove the cover
Pull the old mast out and refit the new one
Refitting is the reverse of removal as they say
peppyuk
Sounds easy enough, cheers.
Ernie Ball
If you want a stubby aerial like the one I mentioned, you should get over to this thread.  "Lord Takuban" looks to be starting another GB.
garethrees
Quote from: "spgreen"they are not difficult
Thanks for this info, should it be in a FAQ?
Cheers Gaz
Hers - 02 UK MR2 Roadster - SP Sports Exhaust, PPE Engineering Sports Cat, Black DOTZ Alloys, Kenwood Double DIN ICE.  SOLD
His - 03 Honda S2000 Silverstone - Stock
His - 96 UK Supra TT Storm Blue (6spd Manual) Stock - SOLD
