addtionnal gauge cover
Started by dreambackup, December 13, 2005, 17:39
Jap GT300
I bought the Varis version in Fibre Glass for £250.
Those din guage slots can be bought for as little as £10
Quote from: "Jap GT300"I bought the Varis version in Fibre Glass for £250.
Is that still available?  s:shock: :shock: s:shock:
I thought it was discontinued, cause it's not on japanparts.com anymore. They only had this one:
 m http://www.japanparts.com/db/partslist. ... 2&small=10 m
Jap GT300
I got it from our varis distributor supastylin.com
so.simple
Tem, are you talking about this?
If so, they still have it, only it is listed under "Interior - Others".
Item: 016-002-010 (Carbon)
Item: 016-002-011 (FRP)
Aren't they just too expensive?
Carlos
Quote from: "so.simple"Tem, are you talking about this?
Ah, thanks  s:oops: :oops: s:oops:
The one from TRD is even more expensive...
Can someone tell me how to remove the stock bin cover? It looks like it should be straight-forward but I can't work it out!  s:oops: :oops: s:oops:
just pull it towards the front of the car, its just on push clips
Quote from: "kanujunkie"just pull it towards the front of the car, its just on push clips
Uh...I wouldn't do that  s:? :? s:?
The hinges are removable, so pull them out first. Use a screwdriver or alike to torque them off. After that the cover will come off.
Quote from: "Tem"
pulled off fine on mine, the hinges are made of ABS plastic, in a C shape that goes on a round piece of bar, breaking them wont happen easily, its in my hands ATM and has been on and off loads
Done it - thanks guys.
It was as you described, Tem. Nothing shifted until I eased the hinge pins out. Looking more closely, there is a slot in each of the pin mounts, presumably for the purpose of getting a screwdriver in to lift them.
