Oil for turbo cars?
Started by spynish, December 17, 2005, 02:40
Quote from: "oilman"1. If the car is heavily modded and heat/oil temperatures are excessive.
2. If the car is used on track and heat/oil temperatures are excessive.
Just curious, but what is a heavily modded car? Turboing a stock N/A engine and doubling the power?
I do think we have issues with heat. Maybe it's the engine location and the lack of airflow, maybe it's something else. Some have reported oil temps of 135C after 15mins of spirited driving and that's without a turbo  s:? :? s:?  I'm afraid to hear what the temps could be with a turbo after 20mins on a track.
And while we have some knowledgeable guys here, can you tell anything about two different oils from something I recently noticed? Dip your fingers in the oil and wipe it off immediately. With brand A, the fingers feel sticky after that, like they never were oily in the first place. With brand B, they feel very slippery, like you couldn't wipe the oil off.
Quote from: "Tem"I do think we have issues with heat. Maybe it's the engine location and the lack of airflow, maybe it's something else. Some have reported oil temps of 135C after 15mins of spirited driving and that's without a turbo  s:? :? s:?  I'm afraid to hear what the temps could be with a turbo after 20mins on a track.
I know my car is not a MR2 but do they have oil coolers as mine did not and I saw temps of 115 on the track, whichis when I backed off. Now I have a decent cooler and it never goes above 90/100 on track and the thernostsat keeps it to 75/80 on the road.
Just a thought
Best regards Alan
mph
FWIW, you'll find that it's not track driving but sustained [European] motorway driving that really pushes the oil temp up. Read: mid-summer with top down, a/c on, averaging 120mph for an hour at a time. This will get the (water cooled) turbo housing to a fairly bright cherry red.   s:shock: :shock: s:shock:
'06 Black MR2 Roadster
'03 Red Lotus Elise 111S
oilman
You're better off with a shear stable 5w-30 or 5w-40 true synthetic oil that has group IV and V basestocks.
Basestock categories and descriptions
All oils are comprised of basestocks and additives. Basestocks make up the majority of the finished product and represent between 75-95%.
Not all basestocks are derived from petroleum, in fact the better quality ones are synthetics made in laboratories by chemists specifically designed for the application for which they are intended.
Basestocks are classified in 5 Groups as follows:
Group I
These are derived from petroleum and are the least refined. These are used in a small amount of automotive oils where the applications are not demanding.
Group II
These are derived from petroleum and are mainly used in mineral automotive oils. Their performance is acceptable with regards to wear, thermal stability and oxidation stability but not so good at lower temperatures.
Group III
These are derived from petroleum but are the most refined of the mineral oil basestocks. They are not chemically engineered like synthetics but offer the highest level of performance of all the petroleum basestocks. They are also known as "hydrocracked" or "molecularly modified" basestocks.
They are usually labelled/marketed as synthetic or semi-synthetic oils and make up a very high percentage of the oils retailed today.
Group IV
These are polyalphaolefins known as PAO and are chemically manufactured rather than being dug out of the ground. These basestocks have excellent stability in both hot and cold temperatures and give superior protection due to their uniform molecules.
Group V
These special basestocks are also chemically engineered but are not PAO.
The main types used in automotive oils are diesters and polyolesters. Like the group IV basestocks they have uniform molecules and give superior performance and protection over petroleum basestocks. These special stocks are used in all aviation engines due to their stability and durability. Esters are also polar (electro statically attracted to metal surfaces) which has great benefits. They are usually blended with Group IV stocks rather than being used exclusively.
It is common practice for oil companies to blend different basestocks to achieve a certain specification, performance or cost. The blending of group IV and V produces lubricants with the best overall performance which cannot be matched by any of the petroleum basestock groups.
Simon
Use the code MR2OC and get 10% Club Discount
oilman\'s website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.ukphone: 01209 202944
