Damn car won't start, started and then wouldn't start again
Started by Ilogik, January 12, 2009, 08:47
if your leaving it standing for days on end get an optima deep cycle, at east if it discharges you won;t kill teh battery
Ilogik
Quote from: "markiii"if your leaving it standing for days on end get an optima deep cycle, at east if it discharges you won;t kill the battery
got a link for them mate?
Really don't know what battery I need. ones I been given all look to big.
Ex: TRD stage 1 TTE Turbo
Ilogik
I currently have this fitted
Banner Power Bull -
 m http://www.bannerbatterien.com/banner/p ... 1_en.php?# m
Type   P40 26
Voltage   12
Capacity K20 (Ah)   40
Colddischarge EN (A)   330
Layout   0
Terminal   3
Max. length (mm)   187
Max. width (mm)   127
Max. boxheight (mm)   204
Total height (mm)   226
Miscellaneous   mGGA
Baseholddown
SimonC_Here
Think you probably mean this:
 m http://www.bannerbatterien.com/banner/p ... ex2_en.php m
Isn't that a bit tall?
Does the battery tie down still fit?
Simon
Quote from: "Ilogik"
 m http://www.optima-batterien.eu/optima-a ... otive.html m
Ilogik
which model number fits the MR-s and is it small or is it a large battery/ Couldn't find the applications.
measure teh space you have, and then compare to teh dimensions on teh website
MRs battery is smaller than the EU anyway so there is always room for a bigger one
Ilogik
Take it you can get the replacement plastic tray then for the underneath, as that is what I was going by with the measurements. Wonder why they changed it for the Uk,
colder weather requires more cranking amps
as your scenario has rather proved  :-) :-) :-)
you can buy niversal plastic trays to suit or just remove the lip a little on yours
wbarrwebster
Where are you based?......I got a spare battery sitting in the garage doing nothing, not new..........this is one I took out when I thought I needed a new one only to find out that my glove box light was on all the time....
B
W. B. Webster
Ilogik
had the battery tested, they said the battery is good, its jsut low charged, the one terminal is loose, just does not want to tighten up, so thinking I will replace it, must be losing charge through that.
trebor
Quote from: "wbarrwebster"
Quote from: "Ilogik"got a link for them mate?
B
There's a Glove Box light!???!  s:? :? s:?
2003 SMT. Astral Black de-badged except for Likwid Art rear badge, JDM front badge. JDM wheel caps, JDM steering wheel badge, JDM style side repeaters. mongos. TTE lowering springs
wbarrwebster
Quote from: "trebor"
Quote from: "markiii"m http://www.optima-batterien.eu/optima-a ... otive.html m
B
Aye, Check out my earlier posts re glove box light, an easy fit using the Fiesta mk 4 switch/light, that's always assuming you dont connect the main lead to a constant juice and run down your battery when the switch dosn't properly cut off!!  s:oops: :oops: s:oops:
W. B. Webster
dipper84
Ive been having a problem with the battery not working after the cold. Ive charged it up overnight and it works for a few days. There isnt a day when the car isnt used. First I thought it was old corroded connectors, I replaced them and the problem went away for a few weeks. It has come back again and has wound me up so much asking for jumps of random people that I have bought another battery. I hope this fixes the problem as there was no initial indication the alternator wasnt working correctly. I will try and check the voltage tonight as I have just aquired a multimeter......
Aylward@
Chris >>>>>
vatovey
I have a battery and alternator testing unit which plugs in to the cigarette lighter if you wanted to test that way.
Testing a battery with a multimeter doesn't really tell you if a battery is bad or not, as the battery needs to be under comparible electrical load like it is when trying to start the car engine.
dipper84
Ive just bought a new battery out of recomendation, ill give it a few days / weeks to see what hapens. it seems to be working fine now even with yesterdays and todays frost.
Chris >>>>>
