The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: Callyuk on April 21, 2018, 09:24
Title: Tein lowering springs
Post by: Callyuk on April 21, 2018, 09:24
Iv recently had to change the front shock absorber on the 2 as it started making a god awefull sound. I thought the top mount had come away so sent it in to my local trusted garage to sort it while I was away. The conclusion was the shock was nackered although it didn't show any signs it was something internal that had gone. I'm running tein a-tech 30mm lowering springs which Iv looked and and are made to run with standard shocks, however the garage seem to think that the springs could have caused the issue. Has anyone else run into this problem or is it just a freak occurrence like I believe it is?
Title: Re: Tein lowering springs
Post by: Beachbum957 on April 21, 2018, 11:42
I have been running Tein-S springs for some time with KYB struts and no issues.  But struts do fail, especially fronts as they handle turning and suspension
If you aren't running bump stops, then damage is possible.  If you hit a lot of potholes, that won't do them any good either.
Post by: Callyuk on April 21, 2018, 13:23
I'm guessing bump stops are fitted, why wouldn't you have them? Car had the springs fitted when I bought it. I just think it was just it's time to fail myself
Post by: 1979scotte on April 21, 2018, 19:40
Another case of a garage talking rubbish.
Toyota sold similar springs themselves.
Never heard anyone have issues with Tein.
How many miles has the car done?
Post by: Callyuk on April 21, 2018, 19:45
Quote from: 1979scotte on April 21, 2018, 19:40
car has done 68k
Post by: 1979scotte on April 21, 2018, 19:51
Quote from: Callyuk on April 21, 2018, 19:45
car has done 68k
Time for a change IMHO.
Not everyone would agree.
They'd be wrong.
:P
Post by: Mr X on April 21, 2018, 20:42
I've had my tein springs on (I fitted them with new KYBs but using the old mounts) for 4 years now and done over 40k. No problems so far!
Post by: Ardent on April 21, 2018, 22:29
Quote from: Callyuk on April 21, 2018, 09:24
Like Scott above, garage talking bollocks. Find s better garage/mechanic.
Toyota TTE spring vs Tein S spring. To all intents and purposes the same spring.
edit
like brake pads n discs n clutches etc, shocks are a wear n tear consumable item
Post by: 1979scotte on April 21, 2018, 23:44
Quote from: Ardent on April 21, 2018, 22:29
edit
Other consumable items exclusively to MR2s rear subframes and handbrake cables.  ;)
Post by: Topdownman on April 22, 2018, 06:35
There is a school of thought about cars in general that says using lowering springs will shorten the life of standard shocks.
Lowering springs are designed to work with standard shocks. Shocks do wear out though but I dont agree that a shock going on a lowered car means that the spring caused this, I think it just wore out.
I dont think you have anything to worry about  but I would change all 4 shocks together to keep the handling sweet.
Post by: Beachbum957 on April 22, 2018, 11:27
Where people seem to get into trouble with lowering springs is not following instructions like cutting the bump stops.  Some just leave them out, which is dumb.  But if you went 68K, it is possible the struts just wore out.  I have seen even Koni's worn out at 90k with stock springs.
A good shop would suggest changing at least both front struts with that many miles and should also tell you exactly why it was making a noise.
Other causes of noise are the bearings in the top mount or even a loose top rod bolt.
Post by: ilovejapcrap on May 31, 2018, 19:43
Just purchased some [emoji4]
