The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: mark1307 on January 16, 2019, 08:48
Title: Wet Floor...
Post by: mark1307 on January 16, 2019, 08:48
Morning all!
I've currently got a wet floor on the drivers side and was hoping someone could point me in the right direction. I have check the rear bins and they are dry as a bone...any thoughts?
M
Title: Re: Wet Floor...
Post by: dan944 on January 16, 2019, 08:55
Door seals?
Checked for any rips or roof damage? Usually where it folds.
Post by: mark1307 on January 16, 2019, 09:01
Quote from: dan944 on January 16, 2019, 08:55
Door seals?
Roof is tip top and nano coated (whatever that is) so i'm pretty sure that's OK. I had a good look at the seals and they look OK but if i am honest i don't really know what i am looking for beyond obvious rips etc.
Post by: Topdownman on January 16, 2019, 09:16
Leak from the  windscreen rubber?
Can you feel any water anywhere on the wiring under the dash or on the carpet to  show where the water is coming from?
Leak from the heater matrix?
How is the water level in the expansion bottle?
Post by: Call the midlife! on January 16, 2019, 09:32
Steering column bulkhead gaiter...
Post by: tricky1138 on January 16, 2019, 09:36
Quote from: Call the midlife! on January 16, 2019, 09:32
That was my thought too!
Also check under the bins in the rear, as I have had them dry but with water underneath them from blocked drains / split in the drains.
Post by: dan944 on January 16, 2019, 09:41
Ooooh this is a great candidate for the new game.
This would probably be my bet :)
Post by: mark1307 on January 16, 2019, 10:19
How do i ask where and what that is without looking stupid....
Post by: tricky1138 on January 16, 2019, 10:37
Quote from: mark1307 on January 16, 2019, 10:19
The column that your steering wheel attaches to and goes through the floor into the front for the car (and to the steering rack).
There is a rubber gaiter in the floor where this goes through and they are known to split / tear and allow water in.
Post by: mark1307 on January 16, 2019, 10:42
Quote from: tricky1138 on January 16, 2019, 10:37
Nice one - thanks. Assume it's and under the car job rather than under the carpet job!?
Post by: tricky1138 on January 16, 2019, 10:44
Quote from: mark1307 on January 16, 2019, 10:42
Should be able to see it and have a feel from the footwell inside.
From outside its the frunk cover off and you should see it.
Post by: Carolyn on January 16, 2019, 10:46
Is the water is in front of, or behind, the seat?
Post by: Call the midlife! on January 16, 2019, 13:07
Sorry, I typed that in a rush, should've been more elaborate.
And for the record, on here there are no stupid questions, just things you don't yet know...
To add to previous explanations, if you wait until it's dark and put a bright light under the car just in front of where the pedals are you should be able to see the light shining through the gaiter inside the driver's footwell. (As long as you don't have the massively bright, interior light on).
You can "feel" for the tears but you're as likely to snag your hand on the jubilee clips holding it in.
For reference you have to split the steering column at the universal joints to fit the gaiter so if your UJ is worn as well it's a good time to do both.
You're looking at around £80 for the parts, depending on what TCB are doing the UJs for at the moment. (Other sellers are available [emoji23]).
Post by: jim_jiminy on January 25, 2019, 18:55
Mine had a wet floor....and it was that the drainage pockets were blocked. And the drainage holes were full of decayed leaves! Cleaned it all up and now is fine!
Post by: StuC on January 26, 2019, 10:38
Quote from: tricky1138 on January 16, 2019, 09:36
If the steering column comes up as no good. I'd follow Tricky suggestion of checking under the bins.
I had a failure on mine there.
