The Workshop => Performance Related => Topic started by: shnazzle on September 2, 2020, 21:44
Title: Stronger gears
Post by: shnazzle on September 2, 2020, 21:44
RRR @Greg rrr has just posted about a company that provides stronger 3rd and 4th gears.
Not sure how they compare to Jubu but worth a look see? @m1tch
Title: Re: Stronger gears
Post by: Gaz2405 on September 2, 2020, 21:49
Yeah these guys have been around a while claim to a have run 500hp through them. (no mention of torque, must be pretty high!)
Post by: m1tch on September 3, 2020, 08:01
Those are the SSC gears, MWR sell them over in the states so good to know you can get them in the UK, as far as I know they have the same rating as the JUBU gears - think JUBU are from Germany, SSC are from Australia.
Torque rating on them are at around 295ft/lbs but a lot run fine at 320ft/lbs - have heard some being run at 370 ft/lbs on track.
Post by: shnazzle on September 3, 2020, 08:12
What are the prices like compared to Jubu?
Not that I'm going to get them haha.
Post by: m1tch on September 3, 2020, 12:50
Quote from: shnazzle on September  3, 2020, 08:12What are the prices like compared to Jubu?
Hanger 111 (lotus parts) sell them, £832 ex VAT so around a grand - coupled with the extra cost to fit them.
https://www.hangar111.com/shop/lotus-2-eleven-gearbox-a-clutch/445-toyota-elise-exige-2-eleven-jubu-racing-gearset-2zz-c64-gearbox.html
Post by: Mark A on September 3, 2020, 17:55
Surely the EB60 in the posts below is a cheaper option? I would have thought anything used in a 2.2 diesel turbo should be plenty strong enough? I'm sure Patrick Chambers has done an EB60 conversion for a ZZW30.
Post by: Gaz2405 on September 3, 2020, 17:58
Quote from: Mark A on September  3, 2020, 17:55Surely the EB60 in the posts below is a cheaper option? I would have thought anything used in a 2.2 diesel turbo should be plenty strong enough? I'm sure Patrick Chambers has done an EB60 conversion for a ZZW30.
It would be close, but you'd have to fit an lsd to the EB/EA6x.
I'm on the fence for both options.
Post by: Dudi on September 6, 2020, 22:20
Also if you're planning to track the car consider some gearbox cooling because large and wider cogs will produce considerably more heat as a coefficient of increased friction.
Post by: toyofan on September 7, 2020, 20:33
Thats the EA box your thinking of.
Superstrong, but not suited for a sportscar, my Auris does 60mph on 2000rpm...
And over 60kg without LSD
