0 Members and 21 Guests are viewing this topic.
Quote from: Carolyn on August 23, 2018, 16:58
A £45 rebuilt head?
If it sounds too good to be true...
Haha that was just the current bid mind. I doubt it'll go for that! If it does look like it'll go for that I'll put in a bid!
And then matching cams, valves and buckets?  Or does it come with all that?
Attempting to do Carolyns mod to the clutch slave clip thingy...
Yeah
Attempting! Not too sure how far too cut!!
Quote from: shnazzle on August 23, 2018, 21:24
Clever!
So at the end of today, here is the current state of play:
- In theory everything electrical is unplugged apart from a cable going to the alternator which I will try and get to as I lower the engine.
- driveshafts are out
- all fluids are drained (only got 5l of coolant out so far...)
- and I'm trying to figure out Carolyn's modification idea to the clutch slave thing I just don't know how far to cut.
- soon as it's done I will then be able to release the engine mounts and lower it down.
the whole of today would not have been possible without Mike's help!  he's being absolute champion and legend driving an hour and a half to get to me I really really appreciate it!
the next full day I get to work at the car will be Monday or Tuesday next week.
Until then it'll just be evenings.
Need to build a shopping list of stuff to order... So far I'll need:
- new exhaust manifold studs and nuts
- cat donut gaskets
- might need new 3 amigos as one of them stayed behind... I only got the nut off.
- do I need new gasket/ seals for the drive shafts?
Quote from: jvanzyl on August 23, 2018, 23:24
- cat donut gaskets
Yes on the last one. Especially the nearside seal
Right thank you.
When your say "seal" do you mean that spring like thing?
Quote from: shnazzle on August 24, 2018, 00:17
- cat donut gaskets
Quote from: jvanzyl on August 23, 2018, 21:13
Take the flat retaining clip out, move the fitting out of the bracket,  cut.
Quote from: Carolyn on August 24, 2018, 07:41
Much obliged! :-)
Quote from: jvanzyl on August 24, 2018, 06:32
Right thank you.
- cat donut gaskets
New drive shaft seals (Nearside: 90311-35064, Offside: 90311-35065). Optional but best replaced. Approx 20 quid for both
Thanks man! That saves me so much time!
Just got the quote from Toyota for the parts... Ouch..http://cloud.tapatalk.com/s/5b7fdd7b1efba/doc09903820180824102316.pdf
Forgot to order Toyota parts! :-(
Will try and call up in the morning...
Lessons learnt so far:
Wiring harness should come out WITH the engine... Unplugging whilst in the engine bay is in the words of Carolyn "Daft"...
Obviously ground cables should be detached, but that's it.
ALWAYS wear safety glasses. I just had a very uncomfortable night due to a scratched eye as some bit of car/dirt landed in it when I was struggling to detach the cables that I shouldn't have been... Anyway.. Could have been worse.
This evening's progress has been that I've managed to do Carolyn's mod on the slave cylinder thingy.. (I bought a cutting disc Carolyn!)
I'm now going to try and make my engine dolly and THEN drop the engine.
tomaky
Doh. Times like that you need a claiming voice haha. I got my gdads old wardrobe on wheels. Knocked the sides off and walla a dolley, you can re force the base but fundamental it does the job.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Late last night I'd pulled through the loom out to the engine side, and then tackled the big coolant pipe that sits behind the engine.
Apparently good practice is to disconnect from the car side rather than the engine as otherwise it's a pain to reattach..
And just as I'm writing this I'm wondering if I've got this the right way round....err... Oh well. I was all have for a bunch of coolant coming out of it, but for some reason it didn't.... So there's still a fair bit of it some where!
Then finally I worked on the engine dolly which had now got the basic frame and wheels attached, all I've got to do is add the extra height on the gearbox side of the sump to hold it level...
Don't forget the dolly has to support engine and gearbox.
Yeah.... it'll either work or if won't!
I'll just have to Jack it back up and re- engineer it..
Anyway!
Time to undo somene engine mounts!
I've got it supported by the Jack and the engine crane...
Quote from: jvanzyl on August 25, 2018, 13:05
Have you drained the block with the tap on the side?
Yup
Quote from: jvanzyl on August 25, 2018, 22:14
Yup
Thought you would have, just throwing it out there [emoji23]
Front mount is off!
Was expecting a bit more wear on it?!
