*Another*Unichip question
Started by peppyuk, February 17, 2006, 21:34
peppyuk
Quick question, My unichip has 2 switches, one switches between map A and B, and the other is an on/off switch, if I switch it off will the car stop, or will it run the stock map from the ECU?
\'In a state of mental numbness\'
if i remember rightly it turns the whole system off and stops it starting, i'll have to try it to confirm though
SimonC_Here
Yep the on off switch takes power off the main ecu as well.
Good for resetting codes, not so good for driving.   s:lol: :lol: s:lol:
And don't switch the maps while the car is on and running.
Simon
peppyuk
Cheers for the info chaps.
Quote from: "SimonC_Here"And don't switch the maps while the car is on and running.
you can do, but it will stick with the one the engine was started on  s:( :( s:(
peppyuk
Quote from: "kanujunkie"
Don't you just leave it on map B ?
SimonC_Here
Quote from: "peppyuk"
Depends where the map you want is!
Mine is actually mapped the same on both settings as milway couldn't work out how to set only one map. Don't know if they still have this problem or not.
Simon
Yours was a pre-mapped chip matey, here are the results of the dyno as promised:
Here are some more details:
Summary:
Power at flywheel (corrected) 163.4 BHP (DIN 70020)
Power at Flywheel (PWR Wheels+Pwr Loss) 167.4 BHP
POWER AT WHEELS 139.5BHP which is MASSIVE i thought?
Power Loss (tyres etc) (calculated) 27.9 BHP
Barometric PRessure: 1030Mb
peppyuk
Can't wait to get it fitted, but going to wait till Mr T has fixed it first, oxygen sensor went on the first day I got the car!
I've just checked mine and the muppets who refitted my ICE which had to go back for repair switched the power switch off. They probably though they were something to do with the ICE set up  s:? :? s:?  They also managed to change the sub amp to high pass when it was naturally on low pass so I had to remove all the plastic panels to change back. Total muppets as with all so called specialist ICE companies I have had the good luck to frequent. Morale of the stroy is that I should have put the repaired components back myself  s:cry: :cry: s:cry:
golden rule, do it yourself  s:? :? s:?
Quote from: "kanujunkie"golden rule, do it yourself  s:? :? s:?
Yes I know but they removed the H/U etc to send away for repair as I don't have a set of pins to get it out and offered to put it back free and said their was a earth problem on one of the maps. They fixed it for free but ballsed up everything else  s:? :? s:?
peppyuk
If I leave the Unichip fitted while the car goes back to Toyota will they be able to tell from the OBD2 port that it has a unichip fitted?
nope, its completely undetectable.
peppyuk
Awesome  s:D :D s:D
well unless they take the plastic bins out the back  s:? :? s:?
Quote from: "peppyuk"Awesome  s:D :D s:D
of course, mk1 eyball will never miss the extra harness and box
