Upgrading brake fluid
Started by Anonymous, March 3, 2006, 11:31
Getting the brake fluid changed to a higher spec, probably 5.1 Question is, how much fluid is needed to flush the system through and then for a complete change?
Roo.
IIRC, i had a tiny bit left over from 2 quarts
Is that quarter of a litre? Or some old measurement?
SimonC_Here
quart (kwôrt) pronunciation
n.
   1. (Abbr. qt. or q.)
         1. A unit of volume or capacity in the U.S. Customary System, used in liquid measure, equal to 1/4 gallon or 32 ounces (0.946 liter).
         2. A unit of volume or capacity in the U.S. Customary System, used in dry measure, equal to 1/8 peck or 2 pints (1.101 liters).
         3. A unit of volume or capacity in the British Imperial System, used in liquid and dry measure, equal to 1.201 U.S. liquid quarts or 1.032 U.S. dry quarts (1.136 liters).
   2.
         1. A container having a capacity of one quart.
         2. The contents of such a container.
[Middle English, from Old French quarte, from Latin quārta, feminine of quārtus, fourth.]
Simon
sorry i got it wrong  s:oops: :oops: s:oops:   just checked and you need aboul 800ml so a 1L bottle will do
Quote from: "kanujunkie"sorry i got it wrong  s:oops: :oops: s:oops:   just checked and you need aboul 800ml so a 1L bottle will do
Confirmed. I bought 3 x 500ml of Motul RBF from Opie, and got 1 1/2 bottles left
Quote from: "roger"
RBF = Racing Brake Fluid (DOT4 high-spec) right?
Quote from: "Roo"RBF = Racing Brake Fluid (DOT4 high-spec) right?
Yes. Its boiling point is even higher than DOT5.1, though IIRC it does somewhere refer to DOT 4. TBH haven't tried to figure out what all these DOTs actually mean.
Cool, thanks. Yeah I just had a look at the spec sheet, and it is top stuff from what I can see. Boiling points etc very high. Just added some to my order   s8) 8) s8)
Roo.
karlus972
I bought 2 weeks ago some break fluid DOT 5.1 and you need less than a liter
Madinina Style!!
looks like Roger and myself are using the same stuff, Motul RBF600. Good stuff
you don't really want 5.1, it's silicomne based and unlesss your changinf regulalry like a race team does it will not last as well as DOT 4, it al;so isn't compatable with teh other fluids so needs a complete flush before using.
RBF600 is teh stuff you want
Just double checked and its def. RBF600 I've ordered, which is good!
Roo
Quote from: "markiii"you don't really want 5.1, it's silicomne based and unlesss your changinf regulalry like a race team does it will not last as well as DOT 4, it al;so isn't compatable with the other fluids so needs a complete flush before using.
RBF600 is the stuff you want
Just to be slightly pedantic - I think it's usually DOT 5 that's silicone based, while DOT 5.1 is DOT 4 compatible (I double checked Motul's - their 5.1 is non silicone, seal safe and can be mixed with DOT 4 in the system).
However that's all a bit moot - the boiling point of RBF600 is considerably higher than the DOT 5.1 anyway  s;) ;) s;)
philster_d
Switched to 5.1 when installing the goodridge brakeline gb (and teins)
