PRE CAT GASKET REF NUMBERs????
Started by Anonymous, March 7, 2006, 12:56
Does anyone know what the ref numbers are for the 2 gaskets I will need to replace when I get the Pre-cats done on my car?
edward.carter
Superb
Thanks very much
edward.carter
you might want the manifold gasket too, not sure of the part number but toyota parts desk be able to find it for you. there not essential but worth it for a few quid
I think it is T90917-06065.
thanks
does anyone know the other gasket number as I think there are 2 or are they the same gasket on both ends?
only gaskets you need are the 2 gaskets between the header and the cat as posted in the link above
Cheers Stu
just for ref, the block to header one is a flat plate/shim style seal and can be re-used
So I only need one new gasket Stu?
Quote from: "daz8365"So I only need one new gasket Stu?
no 2, the 2 round ones between the header and cat as pictured and listed in the link
Is it worth ordering a set of bolts / studs in case of the dreaded shear?  Surely these can't be too expensive and would ensure the car is off the road for the least amount of time as. i.e. not requiring a further parts order and a trip to Mr T because of a  rounded / snapped.  Part numbers?
Has anyone replaced them with stainless studs / bolts?
Quote from: "ShaunyF"Has anyone replaced them with stainless studs / bolts?
http://www.mr2roc.org/phpBB2/viewtopic.php?t=3507&start=200
Last few replies on this page....
