softtop fit
Started by ChrisHumes, March 30, 2006, 07:15
ChrisHumes
Hi
Ive had the softtop down for about 6 months (with hardtop on!). Took hardtop off last night and when I pulled the softtop up i noticed that it doesnt seem to be as good a fit around the sides of the car (whee the hinges are on the hood?
Has anyone experienced this? Will it leak or anything?
any views on this?
Ta
If you mean what I think you mean, you might need to help the sides a bit with your hands when you pull it up. My outer edge seems to go to wrong side of the seals when it has been down for some time.
If you didn't mean that, can you take pics of it?  s8) 8) s8)
darrenjuggins
Once its been in the sun a bit you should be alright.
Not sure about the inside / outside thing, are you talking about the windows ? if so you should put the windows down slightly before putting the roof up, else you will struggle.
If i've mis-interpreted your comments, apologies.
Darren J
Darren A. Juggins
